Old 18th November 2006, 03:47 AM   #1
Default CSS FR125S, will this work?
I'm in the possess of planning a HT set-up for our bedroom and I'm thinking about using the CSS FR125S. I'd like to build the cabinets as narrow and slim as possible and maybe a 10 degree tilt on the baffle so I can mount them right into the corners of the room. How slim and narrow can I get away with?
The receiver puts out 130 watts x 5. I don't think the drivers will ever see full power but on some occasions...who knows? Would it be better to use 2 drivers in a 14 liter enclosure? Should I get the 4, 8, or 16 ohm version?
Thanks very much for your patience!
Brian
Old 18th November 2006, 04:05 AM   #2
maxro is offline maxro  Canada
maxro's Avatar
As far as I know there is only an 8 ohm version, which would be the right one anyway, if you did have the choice.
Are you using a sub? That will take a bunch of load off the FRs and allow for higher SPLs. 130watts per channel is a whole lot and they certainly won't handle that, but then neither will your ears. Just don't turn the volume too high and you'll be fine. Generally, underpowered amps are more of a problem due to clipping if over-driven.
If you are planning on putting them in the corners, then how about a triangular (picture a square cut diagonally in half) cross section. I'd probably shoot for a volume of about 10 litres, sealed. Or, if you aren't using a sub, then go ported, or a mass-loaded quarter wave design of some sort (do a search for MLTL).
Max
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt
Old 18th November 2006, 04:11 AM   #3
maxro's Avatar
Oh, and about the two drivers in one box, it will cause comb filtering effects at higher frequencies, so is to be avoided. That is if both drivers are on the front baffle, if you go bipole (one front, one rear), then that's a whole other story...
max
Old 18th November 2006, 04:13 AM   #4
Thanks Max!
I will use a sub... is that 10 liters for one driver?
Old 18th November 2006, 04:15 AM   #5
OK then... Thanks!
Old 18th November 2006, 04:26 AM   #6
Send a message via AIM to Spasticteapot
Wait..."narrow and slim?"
You need a "Bigger is Better"!
http://www.zillaspeak.com/bib.asp
Bass down to 30hz!
Old 18th November 2006, 04:28 AM   #7
That would certainly be nice but this system is for our bedroom and there is just not enough space
Old 18th November 2006, 06:31 PM   #8
nodiak is offline nodiak  United States
nelsondog,
YMMV but I get too much midbass boom with 10L sealed, even pulled out 6 ft. from front wall. Only 2.5 ft. from side walls as room is only 11.5 ft. wide, but 26.5 ft. long.
I'm thinking of going aperiodic, the person I bought the FR125s from included a pair of Scanvents to use. I think I will build a 13L box too as many have said that works well.
I'm interested in what you come up with as I also plan to use the FR125s in a small HT with sub. Will use 30 watt JVC EX-A1 with it's subout.
Don
Old 18th November 2006, 06:38 PM   #9
I'd be very interested in your findings...just curious, have to tried placeing them directly into the corners of the room? This is my plan. I wonder what would happen?
Brian
Old 18th November 2006, 08:01 PM   #10
Well, just for a quick test I put them on 26" stools in the corners. It actually sounded pretty good as all the reflection from walls gave some missing sparkle to the mids (which out in the room are resessed). And the mid bass/bass wasn't any more exaggerated like I thought it would be - maybe because the mids level was raised.
Imaging was of course fairly flat on the front wall so I missed the depth i get normally. But again the fr is better, because of my untreated walls imo.
Good call, I may go this way with these drivers. But I'm working on bass traps for those corners. I'd hope when I put them on either side of tv, just 2' out from front wall they'll still have much of this improved midrange response. I'll see later.
Thanks for the inspiration.
Don
Fr125s Bib cangaceiro99 Full Range 16 26th August 2008 06:16 AM
My take on FR125S in OB Rafal Full Range 37 22nd March 2008 10:20 PM
CSS FR125S 2 way OB Rafal Full Range 19 10th October 2006 03:56 PM
css fr125s joe perry Full Range 5 10th May 2006 04:11 PM
FR125S in TL? robertG Full Range 37 27th March 2006 03:58 PM
Page generated in 0.11022 seconds (74.37% PHP - 25.63% MySQL) with 10 queries
