support for small full range
Old 16th November 2006, 03:29 PM   #1
Artmaster is offline Artmaster  Ukraine
Artmaster's Avatar
Default support for small full range
gday!
I made it finaly. FE87 sealed. 1 litre box. it's working as it's can 150 hz - 30kHz. it's prety not much. and I like bass.
that's why I tie to Fostex additional woofer. band pass 4 order. it's working 2 octaves, not all of time - depend of music and sounds very good. comfortable.
bi-amping, bi-wiring , very simple active filtres, amp's TDA2030 and 2030A.
stabilized PS for FE87. ... otherwise I couldn't listen it.
I call it - "Lounge". I like it and I will make it by onyx.
have to be nice view. isn't it?
do you have any suggest for this idea?
Artmaster live in https://www.youtube.com/Depo196
Old 16th November 2006, 05:44 PM   #2
Spasticteapot is offline Spasticteapot  United States
Send a message via AIM to Spasticteapot
My suggestion would be to use a small woofer driver, as made by Vifa, Audax, and the like.
Instead of a passive crossover, I'd reccomend going "active". A pair of Amp32s from 41hz.com is only about 55$ USD (not sure what the VAT is), and the sound quality is excellent. They're also about the same size as a ten-watt inductor.
Use one amplifier per channel, with an active filter (an op-amp plus some tiny caps and inductors) as a high-pass for the FE87 and a low-pass for the woofer.
As an added bonus, you can connect 'em directly to a preamp - the power amplifiers would be built in!
Also, you can power them off a 12v car battery, or a computer power supply.
Old 16th November 2006, 08:29 PM   #3
Geoff H is offline Geoff H  Australia
First, try the cabinet on a deeper shelf. I think the energy from the port is being lost under the shelf, rather than reinforcing that off the cone.
Secondly, I am working on 2 wide range systems at present. Both need (or I want) bass assistance. My experience is better results with full range to the full range driver, and tailor the sub xover to suit.
The only reason I would place a x-over on a full range driver, would be due to power handling requirements.
edit: My "little" system, 3" drivers in folded TLs, driven from a TDA2007A, is better with a regulated 19v supply.
Old 17th November 2006, 07:01 AM   #4
Artmaster's Avatar
gentlemen! thank you for your reply.
of course I use active crossover and separate amplifier for Fostex and woofer. TDA2030 +-15V stabilized for Fostex and +-20V for TDA2030A for woofer.
in the beginning I planed to use Monacor SPH-115 woofer, but latter choosen Edifier EDF-131-3 woofer as well it's has more deeper bass and shielded. you can see it at the bottom of picture.
about crossover. at start I used circuit cross1.jpg attached.
now I use simple 2 order for woofer and 1/2 order for Fostex .
it's just working better for me.
about box. now it's plywood 20 mm. band pass has 2 cameras about 3.5 litres each. Fostax has about 1 litre sealed.
latter I'll make it by onix and it'll be strong and noiseless.
I'm always being made loudspeaker by marble and other stones. I like it.
Old 17th November 2006, 12:42 PM   #5
Yuri, thanks for comments about stones. I thought I might show a lack of modern terms by asking about onyx.
Interesting. Do you carve from a solid block or bond panels together.
And how do you drill holes to mount the drivers? I once looked at slate tiles for midrange baffles, but lacked the knowledge on cutting the holes in stone.
Have you any pictures of marble cabinets? I am visualising onyx open baffles.
Old 17th November 2006, 01:09 PM   #6
Artmaster's Avatar
dear Geoff H!
holes for stone - it's difficult to do. especially beside border.
I do not make it myself. it's my partner - company being made it using hydroabrasive cutting. do you understand it? my English very simple, sorry.
see attached my old , but favorite subwoofer.
all of marble, or other stone loudspeakers I made from slab 2 cm and glue it. then - polish. to tell the true - it's not expensive - the same like wood. but aesthetics - very high.
I choose onix this time and top and bottom plate will me malachite 1 cm thick. hope it will be good view.
Old 17th November 2006, 03:28 PM   #7
Originally posted by Yury
dear Geoff H!
I think that's called "waterjet cutting".
Nice speaker! I wonder how hard it would be to produce a thin granite veneer for wood?
Old 17th November 2006, 11:02 PM   #8
Yuri, you do not need to be sorry for your English (it's a silly language anyway)
The sub looks great. Onyx will look good. I am thinking of 1.5 metre high transmission lines. (They could become headstones)
I do know about hydro abrasion, having worked in several places where it is a problem.
Great ideas.
Old 20th November 2006, 08:59 AM   #9
Artmaster's Avatar
don't know about TL. TQWP looks nice. I made it a few. and planed to made by marble. but got no nice sound. insufficient bass.
support for small full rangeHide this!Advertise here!
Recomendation needed, small cheap full range. internecine Full Range 26 27th May 2009 08:36 AM
Full range flat arrays (big or small) ? norman bates Full Range 7 15th April 2009 11:51 AM
Full range and/or High Efficiency possible in small cabinet? Seraph Full Range 29 19th June 2007 01:13 AM
Help selecting a small Full Range mimir Full Range 9 31st August 2005 05:41 AM
Driving small full range ribbons setmenu Multi-Way 6 10th January 2003 11:38 AM
