Hey all...just picked up a set of Logitech "computer" speakers for next to nothing, and they have these neat 3" full range drivers with aluminum phase plugs. Not bad for $5 each. My plan is to junk the plastic cabinets and build a set of "real" enclosures for them, add BSC if necessary...basically see if I can get some decent sound out of these
What would you guys recommend? I'm kinda looking at the Fostex FE87 recommend backhorn as a starting point, but English unit plans would help a lot Thanks in advance.
Jim J. |
#2 |
#3 |
You can't divide by two and a half?
#4 |
http://xoomer.alice.it/0galavot/limes.html
That's exactly what I'm looking for, but there are no dimensions given, and the link doesn't work to the plans
Jim J. |
#5 | |
is there a way to find out if the tangband W3-871S would work? thanks gychang |
#6 |
6x6x29in (external). It'd be easy enough to investigate an ML TQWT like these using similar dimensions for the aforementioned drivers.
#7 | |
Here or elsewhere I fielded a question about the noogies and and the tangbands. This seems to be a fit for the Voigt pipe question but I have no idea on how to do the measures. |
#8 |
Search for: cyburg's needle
Like: http://www.plastichead.net/audiowork...es/w3s-871.htm Made them but with 4 inch units.
Daisy Bell |
#9 | |
Ya gotta love it. I tried some floor standing experiments with TB's using PVC. After that I decided they belonged on the desktop and so the Voigt/Noogi looks like a better solution. It's better for the following reason: most Voigts, while eclypsed by other designs for floor-standers, are always described as 'forgiving' as far as a build goes. At 30 inches or so and with the drive down a bit, it puts the listening height pretty much in the zone for desktop. |
#10 |
Not voight pipe but I used logitech 5300 speakers to make TB3 bipole by Salas. Really like them, small and easy to build. Search for TB3 in this forum.
| Folded Voigt Pipe | Ropie | Full Range | 18 | 2nd November 2005 03:31 PM |
| MTM on a Voigt Pipe ? | johninCR | Full Range | 2 | 8th April 2005 06:20 AM |
| Test run of 2-way Voigt Pipe | Timn8ter | Multi-Way | 11 | 21st January 2004 04:17 PM |
| Page generated in 0.11448 seconds (76.53% PHP - 23.47% MySQL) with 10 queries |
