Old 12th November 2006, 08:24 PM   #1
pekar is offline pekar  United States
pekar's Avatar
Default Delsol- inexpensive full range bookshelf.
Here's one I've been keeping under wraps, but it's time to share.
Use the Aura NS3-194-8E, on sale for $10.50 from Madisound.
http://www.madisound.com/cgi-bin/ind....9881&pid=1705
Ignore the fs, it does far better than the numbers indicate.
Especially in my box.
One half sheet of MDF (you might could squeeze it out of a quarter sheet, with no mistakes)
Some padding for the back wall ( felt or carpet pad)
2"dia PVC (you can play with the port size)
1/2"hardwood face, or use 1/2" MDF or birch ply if you have to, but it won't sound as good. Mine is maple.
I developed this for use with the t-amp, and have found it works very well with the higher powered amp6.
I present this as an experimental starting point, and welcome suggestions.
design goals were-
cheap,
simple,
audiophile sound,
no crossover, just a driver (mechanical mods only),
rock the party.
plans at -
http://www.flickr.com/photos/47642593@N00/295706737/
Just build 'em- I think you'll be glad you did.
Pekar
Old 12th November 2006, 08:35 PM   #2
pekar's Avatar
Bottom pic. These are prototypes, I have yet to make the pretty pair.
Old 12th November 2006, 09:03 PM   #3
Scottmoose's Avatar
Reminds me of the Hawaii 5.0 for the defunct RS40-1354. Nice work.
Old 12th November 2006, 11:44 PM   #4
Default question about the porting...
wondering if the pipe section can be replaced with a rectangular section of vent that runs up the inside of the back wall? You might even get away with just a slot in the bottom at the back edge. That way if you place a bottom on the cabinet you can stand mount the speaker and your vent still works. Is there a special interaction going on between the two vent sections in this design? As it stands the vent action will be modified depending on what kind of surface the speaker sits on (ie. smooth floor or carpeted). Comments? Regards Moray James.
moray james
Old 13th November 2006, 12:34 AM   #5
Send a message via AIM to Spasticteapot
Memo to self:
Buy some of these.
Old 13th November 2006, 01:20 AM   #6
gmilitano's Avatar
Nice little inexpensive project.
What sort of finish are you planning for the enclosure?
Old 13th November 2006, 04:17 AM   #7
pekar's Avatar
I intended that these be set on a hard surface like a desktop or bookshelf, not the floor. It would be easy enough to incorporate a bottom for other uses.
You can do whatever you want with the vent, but
I already tried the slot idea, with inferior results. Vents along walls are generally a bad idea.
I plan to use some birdseye maple for the face, with a painted body.
Old 13th November 2006, 08:29 PM   #8
Default system Q and subjective sound
Trying these same drivers in small sealed box, what volume and tuning freq are you using and are you happy with the sound? Ref my thread aurasound 3" I still think a TL is the solution but haven’t gotten any feed back yet. And to james as long as you know then box tuning freq a rect port should be easy to calculate.
Old 13th November 2006, 09:31 PM   #9
Default Slot vents tend to...
provide
a broader BW in terms of load as compared to round or square ducts.
Seemed simpler to construct with all rectangular vents and I can see no advantage to switching to a round tube duct (in keeping with the design goal of ease of build). You could stretch this into two ducts and have a mini Onken design. This would also provide some internal cabinet reinforcment. Regards Moray James.
moray james
Old 14th November 2006, 01:19 AM   #10
pekar's Avatar
The attached pic. is similar to what I tried, and was unhappy with the result.
Your idea is interesting, reminds me of the Solo-103.
This box is really quite small, and with 3/4" walls needs no bracing, IMO.
Pekar
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
simple, full range, bookshelf dsavitsk Full Range 8 15th February 2007 07:18 AM
Simple, Inexpensive, yet Decent Full Range/Single Driver system? dsavitsk Full Range 11 16th August 2006 10:40 PM
Building a full range bookshelf enclosure aussiebuddha Full Range 6 10th August 2006 04:31 AM
Page generated in 0.10523 seconds (78.80% PHP - 21.20% MySQL) with 11 queries
