Old 10th November 2006, 12:15 PM   #1
gychang is offline gychang  United States
Talking small bookshelf project suggestions please
I have too much plywood left over from 2 BIB projects. Although I am totally sold on the big cabinet with a fullrange, I would like to build a small one for the bedroom (have to be shielded).
I would like to try:
either FE107E (FE103E is not shielded), or HI-VI B3S.
Has anyone built a smallish (hopefully stylish) cabinet that works well?, will be driving it with a t-amp clone, like jazz/classical/vocals.
thanks,
gychang
Old 10th November 2006, 12:38 PM   #2
Kensai is offline Kensai  United States
Send a message via AIM to Kensai
Zaph has one on his site.
He is Mr. Better Living Through Precision Crossovers, and he's not much of an FR fan (this is his only FR design so far).
More simply, you could DL a copy of WinISD or another box calc and come up with a cabinet volume for something that sims within reason. For example, a cabinet with volume of about 295 in^2 with a 2" diameter port of about 5.75" length should have an F3 of about 84Hz. Not great, especially not compared with a BiB but better than a sealed cabinet (couldn't get anything less than about 150Hz). Of course, in these standard box cabinets, you'll have issues with baffle step which will kill more bass unless you use a correction circuit (I'm no help for those) which will kill efficiency, or you place them right up against the wall or in and actual bookshelf to present, acoustically, a much wider baffle.
Maybe someone else has the low down on small folded lines of various sorts or double bass reflex enclosures (don't know much of anything about them other than they exist)
Kensai
Old 10th November 2006, 12:59 PM   #3
Kensai
thanks, Kensai, I will look into how WinISD works.
gychang
Old 10th November 2006, 02:58 PM   #4
Godzilla's Avatar
For a three inch Fostex a Noogi style cabinet is cute:
http://www.cain-cain.com/noogi/index.html
For four inch Fostex these are adorable… there are more cabinets out there to think about too:
http://www.zillaspeak.com/ZillaSpeak...103-RS1197.asp
Somewhat larger would be the Fostex 126/7e… I’m happy with these:
http://www.zillaspeak.com/fostex127eSSB.asp
And of course the Reference Project has some very well thought out designs to choose from.
Peace,
Godzilla
Old 10th November 2006, 05:32 PM   #5
Default Solo 103
For small size, elegance and a lot of scrap plus the small drivers you
want to use, look at the Onken and it's variation the Fonken threads here on the site.
I've been having a problem with Firefox today in making this reply...
I started 3-4 times now and am hitting some key that kills
the answer so I got one going in notepad. :-)
Zaph has done a couple other designs for full range for the Tangband
w871s. One of those was my first scratch build after doing cabinet
mods and experiments with PVC pipe. I have to say I was not satisfied
with the result and am still looking for a good build for the W871s.
The original Fe103 onken by a Europenan builder is very compact and
looks great. I'll see if I can find it again.
Here it is:
http://www.humblehomemadehifi.com/Solo103.html
SMALL horn bookshelf ? Steven-H Full Range 22 14th May 2007 06:49 AM
Small bookshelf design needed x Multi-Way 9 8th May 2007 03:28 AM
Cheap, small bookshelf design... Nm2285 Multi-Way 3 19th July 2005 10:32 AM
Building Bookshelf Speakers - Looking for suggestions soundNERD Multi-Way 26 31st January 2005 08:10 PM
Ultimate small bookshelf? DIYNewbie Multi-Way 88 21st June 2004 07:17 PM
Page generated in 0.08668 seconds (76.54% PHP - 23.46% MySQL) with 10 queries
