Old 9th November 2006, 04:12 AM   #1
Default Upgrading from a 166esr BLH?
I built a Fostex recommended BLH for the 166esr driver about a year and half ago. I've used it with a 2a3 SET amp and have I've throughly enjoyed the speaker. It was my first adventure into fullrange speakers/horns and I must say I am hooked. I'm just wondering where one goes from here for improvement. I've been looking at the lowthers but people seem to have a love or hate response to them, so I'm not sure. Anyone with experience using the 166esr have any ideas on an upgrade path for me?
I like the 166esr's but seem to find a little bit missing on the top and bottom ends. I also find they lose some of their coherency on heavy rock but as I mostly listen to acoustic music I would never want to sacrifice the smooth midrange for more seperation.
Chad
Old 9th November 2006, 08:03 AM   #2
Scottmoose's Avatar
Not easily is the quick answer. The 166ES-R is one of the finest FR drivers around. Fostex know what they're doing. To get a signifiant upgrade, you'd have to shift to Lowthers or a multi-way horn system like the VOTT. Remember, no FR driver, however good it is, is ever going to be as good as a multi-way at rock or, say, big orchestral pieces: they just can't do the massive dynamic swings, though the better ones like the ES-R and Lowthers make a pretty fair fist of it.
Before changing drivers, you might want to try a different cabinet. Simple and quick would be to try a couple of BIB enclosures for them -see www.zillaspeak/bib.asp for ES-R dimensions. Beyond that; I'm currently working on a pair of ~8ft double horns for these, the standard 166, and the 168ESigma. Dave and I have done 3 big chamber, short horn cabinets (see the Spawn of Frugelhorn thread -Harvey, Iris and Bruce, Iris being the one for 6 1/2in drivers) and we're starting on long path, small chamber double horn fairly soon.
Scott
Old 9th November 2006, 10:05 AM   #3
hm is offline hm  Europe
hm's Avatar
Default double horn
one new technic solution would be the
POSAUNE specially made for Manger and Fostex 16 cm:
http://www.hm-moreart.de/7.htm
Old 9th November 2006, 01:22 PM   #4
Could try the 206ES-Rs, or the new 208 coming out next year. Or the top of the heap, as I understand, are the AER drivers.
Old 9th November 2006, 02:35 PM   #5
I'd definitely be interested in how the double horns work out for the 166esr. I always liked the look of the Cain&Cain double horns.
Has anyone did a direct comparision between the 166esr and the 206esr? I was thinking of of the 206esr but wasn't sure if would be significant step up. Also the rumor of the 208esr sounds interesting. Maybe if I waited a 208esr and super tweeter would give me an improvemnent in the top and bottom ends?
I'd love to build a Lamhorn 1.8 type of enclosure for the an AER driver but have never found any DIY designs out there. HAs anyone out there ever tried to design such a cabnit? The AER I think at present is a little out of my price range but something I would definitely try and scrape the money together for if the right DIY design could be found.
Old 9th November 2006, 03:24 PM   #6
Scott, Scott, Scott, what is wrong with you!
You know I am weak!
My 166ES-R BiB's are barely a few weeks old and now you have a new enclosure for me to build?
Everytime I walk into the hardware store they start to smile and ask
"how many sheets of ply today sir?"
So, how many will I need Scott?
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 9th November 2006, 04:59 PM   #7
Scottmoose's Avatar
If you don't indulge yourself in this life, nobody else will
Might take a little while guys as I've got a few things on at present, both in the audio world and elsewhere, but the design should hopefully appear before Christmas.
Re the ply, probably a total of 3 sheets of 4 x 8 for two cabinets. They'll be about 6ft tall with an 8ft pathlength, give or take.
Old 9th November 2006, 06:38 PM   #8
Scott, I cannot believe you would let a doctorate get in the way of important things like hobbies
Well, I am always up to a Christmas present.
Thanks Scott.
Old 10th November 2006, 06:18 PM   #9
paba is offline paba  Canada
Hi all,
I have two 166esr sitting in their boxes and waiting for me to get off my back side and build those fostex BLH too.
I think an upgrade would be expensive... supravox, phy-hp, Aer, lowther, reps.
I've heard the lamhorn fed by 300B and it is great. To bad they don't sell the plans or something.
Myself, I'm thinking that if after some time I want to upgrade it will either be adding sub and super tweeter or if some new cabinet design comes out specifically for 166esr.
I'm also wandering if the DIATONE P-610MB might be an option too.
Or if fostex releases a limited edition version of the sigma series 168ez.
cheers
paba
Old 11th November 2006, 07:24 PM   #10
I also have been using the 166ESR in a back loaded horn. I added a sub similiar to the C & C Baily, using a Seas 10". Major improvement on the enjoyment factor. I am now investigating adding a supertweeter. Thinking of the Fostex T90A as offered by Madisound for their BK16 kit.
I have playing arround with full range drivers for 3-4 years and FE266ESR in the BLH is one of the best that I have heard.
Good Luck,
Bill
Upgrading an op amp in mic pre?? synap2012 Chip Amps 3 7th May 2008 02:26 PM
Upgrading DM2 beamnet Multi-Way 2 7th December 2007 03:00 PM
using the 206ESR cabinet for 166ESR paba Full Range 7 5th July 2007 11:50 PM
Upgrading R50 KEF TL essence Multi-Way 26 29th January 2007 09:15 PM
Page generated in 0.11927 seconds (79.48% PHP - 20.52% MySQL) with 11 queries
