Tang-Band full-ranger in a soffit-mounted system?
Old 4th November 2006, 11:24 PM   #1
Consul is offline Consul  United States
Send a message via ICQ to Consul Send a message via AIM to Consul
Default Tang-Band full-ranger in a soffit-mounted system?
I was surfing around Parts Express, and I came across this:
http://www.partsexpress.com/pe/showd...number=264-842
http://www.partsexpress.com/pdf/264-842.pdf -- The spec sheet
As far as I can tell, it has pretty nice specs and a good response curve (other than those two peaks between 10k and 20k -- more on that later). My application would be a small music studio for recording and mixing, like thus:
As you can see, my plan is to soffit-mount anything I might build or buy into the walls. So, we'll call that an infinite baffle for now. (The picture shows an MTM configuration, but that's flexible.)
So, this Tang-Band driver pops up, and I start thinking about pairing it with a woofer to handle the area from about 30hz up to about 150hz. I've seen some folks do similar things around here, and I'm wondering just how well they think such designs work for critical listening, especially in the mid-range area. I would probably use an active crossover and bi-amp each side.
As for those peaks I mentioned earlier, I'm thinking solution one is simply to try using the speakers as-is, since they might not sound as bad as they look. If I want, I can try tweaking the crossover or add a cap to try to smooth it out.
Thank you for your time.
Old 5th November 2006, 11:24 PM   #2
soongsc is online now soongsc  Taiwan
soongsc's Avatar
Those are quite good for listening, when we were trying out the W3-1231SH, we found that a little more tweeking and mods made them acceptable for a small recording studio. Adding the bass is very good.
Hear the real thing!
Old 6th November 2006, 12:00 AM   #3
I like the specs of the 1231 better, I think. Of course, there's no substitute for trying things out and listening, but the other problem is, apparently, the 1231's are not available in the United States.
Thank you for your reply.
Old 6th November 2006, 06:28 AM   #4
soongsc's Avatar
You might want to consider crossing a bit higher due to the limited Xmax using the W3-1335SB. Probably at around 500Hz. W3-1335SB is said to have better off-axis response, but I have not measured one.
Old 6th November 2006, 01:40 PM   #5
Yeah, I'm reconsidering my choice of full-range driver now. The whole point was to keep any crossover out of the 200hz to 2khz range. Research shall continue.
Again, thanks for your help.
Old 6th November 2006, 09:07 PM   #6
Pano is offline Pano  United States
Pano's Avatar
Cool looking set-up!
If you can build such big enclosures, why go with such small drivers? Is it because you want to use them nearfield at your work station?
Take the Speaker Voltage Test!
Old 6th November 2006, 10:34 PM   #7
I have a ceiling height of 6 feet, 5 inches (my total dimensions are 13'x17'x6.5'). It's not as big as it looks, and right now, the whole area's a mess anyway.
Because of the center jack holding up the floor above (the red columns are jacks), I'm limited where I can place my desk. That means near-field use only.
Also, that illustration is not the be-all-end-all of my final monitoring. I just placed an MTM thing in there to illustrate where the speakers would go, and the way the would mount right into the soffits. The design is still in the making.
I ran across this baby in the course of some research:
http://www.madaboutsound.com/prod_det.asp?product_id=13
It has a lot of desirable characteristics for this application, including being able to crossover at a low frequency for bass (150hz or so). It's Qts is kinda high, though.
Tang-Band full-ranger in a soffit-mounted system?Hide this!Advertise here!
tang band full range line array, thoughts? clearwaterms Multi-Way 9 30th June 2012 10:31 AM
Tang Band W4-1052sd full range drivers for sale. type Swap Meet 1 17th January 2008 06:19 PM
Tang Band W3-871S Single speaker full range audiosteve Full Range 17 6th February 2007 11:23 PM
Foam blocks between 2 Tang Band 3" full range on a small center channel The Paulinator Multi-Way 5 27th March 2003 05:04 AM
