Old 31st October 2006, 05:22 AM   #1
Default Alternate Driver for Jordan JX92S TL Cabinet
I am wondering if anyone knows an alternate lower cost driver that would work well in the TL cabinet design that Neil kaye did such a nice job of building as detailed in the gallery pages and his web site.
http://web.mac.com/noteldov/iWeb/DIY...7951E0B11.html
I want to build a cabinet design that will fit hidden inside a wall with the driver area only stepped out 1/2" to be flush with the finished gypsum wall. This TL design looks like it would fit nicely in the wall. I would have to adjust the vent opening out the front as well.
The idea is to create what looks like a simple inwall speaker but in fact have the benefit of a TL design.
Old 31st October 2006, 11:53 AM   #2
Your best best is a design for your chosen driver, not the other way round.
The jordan has very unusual specifications making it hard to match.
Many designs can be modified to fit into a wall.
/sreten.
Old 31st October 2006, 02:43 PM   #3
Default driver selection
The proposed driver is a FR125S. The shallowest cabinet design is what I am looking for . Sealed cabinet would be simplest to install if anyone knows of a design that has been proven.
Old 31st October 2006, 05:28 PM   #4
Any design can be used, just keep the cross sectional area the same,
or half it in the case of bipoles.
http://www.planet10-hifi.com/boxes-CSS.html
/sreten.
Old 31st October 2006, 06:25 PM   #5
frugal-phile(tm)
planet10's Avatar
Default Re: driver selection
Both the FR125 & the Fostex FE127 work in a simple ML-TL. You should easily be able to accomodate one into the walls -- i've actually done just that with a set of diyAudio Ref FE127e ML-TLs (port exiting closer to the ceiling so the kids won't fill the port with ...
http://www.diyaudio.com/forums/showt...564#post528564
These could be cut in half (lengthways) and used for the FR125. FR125 also works well in sealed (10-14 litres)
http://homepage.mac.com/tlinespeaker...e-MLTL-map.gif
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st October 2006, 08:25 PM   #6
Default CSS FR125S ML-TL Modelling
In my work in designing, analyzing, and building a FR125S/WR125S bipolar ML-TL I do have a single driver ML-TL to describe. All dimensions are internal values:
Line length: 39.56"
Driver centered 14" from top
Port Located 37" from top
Cross-sectional area: 21.75 sq. in.
Stuffing density: 0.50 lb.-ft3
Port diameter: 2.125"
Port length: 3" (50 Hz F3) to 4" (45 Hz F3)
You can vary the port tube between 3" to 4" long depending on how low you wish to go for the 3 dB down point.
This design models very flat and will sound great.
Jim
Old 31st October 2006, 08:36 PM   #7
Scottmoose's Avatar
Dave, how about that WB 127 based folded quadratic taper design you did a little while ago? Should be ideal.
Old 31st October 2006, 10:11 PM   #8
frugal-phile(tm)
planet10's Avatar
Yes, there are numbers for a Metronome for the FE127. As well i've drawn a Tombstone/PAWO format ML-Voigt for the FE127.
dave
Old 1st November 2006, 10:07 AM   #9
Personally I'd go for the WR125S + supertweeter.
/sreten.
Old 1st November 2006, 11:18 AM   #10
Scottmoose's Avatar
Port length by memory for the WB design above needs to be between 1in & 2in depending on taste, & using the FE127E. The CSS drivers should go in if you increase vent length to 3in.
Looking for Jordan JX92S oshifis Swap Meet 3 26th September 2011 12:44 PM
WANTED - Single Jordan JX92S Driver boudy Swap Meet 0 5th February 2009 01:33 PM
WTB: Single Jordan JX92S driver Nikola Krivorov Swap Meet 0 10th August 2008 07:50 PM
Jordan JX92S Gaffer74 Full Range 11 31st May 2006 09:42 PM
Jordan JX92S driver speaker design Gaber Multi-Way 25 23rd August 2002 08:01 AM
Page generated in 0.10588 seconds (86.59% PHP - 13.41% MySQL) with 11 queries
