Old 5th February 2007, 10:06 PM   #101
wixy is offline wixy  Australia
Im using MDF for the construction. I was going to biscuit join the main pieces of the cabinets, but now I think I might as well just glue everything together and save some money by not having to buy a biscuit joiner.
Old 6th February 2007, 02:04 AM   #102
I use biscuits to help keep pieces aligned while I apply the clamps, but they don't add to the strength of the final joint. If you're more careful (and patient) than I , butt joints will work fine.
Old 6th February 2007, 02:23 AM   #103
Really? I thought the purpose of biscuits was to provide extra strength for the joint, and I also thought that biscuits allowed for some movement in the joint when two pieces of wood are initially joined. Please correct me if I’m wrong.
Thanks for the tip, if that’s the case then I might just try to be very careful when applying the clamps to make sure everything lines up straight rather than use biscuits.
Old 6th February 2007, 08:14 AM   #104
hugz is offline hugz  Australia
People often say (and it has been similar in my experience) that a glue join will be stronger than the MDF itself. That is to say that if you were to try to break two bits of glued together MDF apart, the wood will actually snap before the join fails
Old 6th February 2007, 02:31 PM   #105
Pit Hinder's Avatar
Send a message via ICQ to Pit Hinder
Yes to that. (*sniff, sob, looks for beer*) No answers yet from Kangarooland as to brand names of good vinylic, let's hope someone shares his knowledge. And bisquits...if you like to build something with Lego toys and love 90° angles they are good fun, but not worth to have your sister marry them. Back to acrylic: you don't need dozens of clamps, and clamping crazy angles is something else anyway. Come on, tell us - what is your favourite glue?
Pit
Old 6th February 2007, 06:37 PM   #106
frugal-phile(tm)
planet10's Avatar
Originally posted by Pit Hinder
And bisquits...
I understand that you also end up with a weaker joint. Really good if you need something to help you line stuff up.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th February 2007, 06:44 PM   #107
Pit Hinder's Avatar
[i] Really good if you need something to help you line stuff up.
[/B]
Yes. But a workbench and a wall you know to be at 90° is fine.
Old 6th February 2007, 09:19 PM   #108
zBuff is offline zBuff  New Zealand
After a bit of search I finally found out what this "Vinilic" glue that Pit Hinder talks about. It's just plain old PVA, Polyvinyl Acetate, white glue. No too sure what the best brands are though
Old 9th February 2007, 09:19 AM   #109
I have a question about cutting the hole for the driver.
I notice with a lot of pics I see of speaker constructions that people cut the same hole with two different diameters on either side (its the best I can describe it, don't know the technical term).
Is it necessary to do this or can I just cut a hole and be done with it?
Also, another question, Fostex say to use 'sound absorbants' in certain locations as shown on the plan: http://www.fostexinternational.com/d...ez_enclrev.pdf
What could I use for this?
Old 9th February 2007, 12:56 PM   #110
just cut the hole in the normal way, it doesn't do anything cutting in that strange way. All the small thing don't do notinhg, we're talking about millimiters.
you could use the interior of pillows. wich is made of acrilyc material or polyester.
But the best thing you could do is using plywood instead of MDF. If you want to stay on cheap use the chipboard of good quality.
Fostex 206E ML TL panord Full Range 16 7th January 2013 05:48 PM
WTB: Fostex 206e or 207e d to the g Swap Meet 5 28th October 2009 06:36 PM
Fostex 206E in Big Fun Horn atilsley Full Range 0 8th September 2008 06:23 AM
fostex 206e's WANTED brettleasure Swap Meet 5 29th August 2005 12:56 AM
fostex fe 206e drivers bossco Multi-Way 0 24th April 2005 06:30 PM
Copyright ©1999-2013 diyAudio
