#11 |
The dust caps on the 126s and 127s must be very inviting. I didn't even have 5 hours on my speakers before my son's friend popped one in.
I poked a hole in the tip with a pin and pulled it back out with a piece of wire. Then I sealed the hole with glue. Now I really need to do the puzzlecoat mod and hid the discoloration. pete |
#12 |
Apa's DIY
opinions on the sound quality after the mod?
thanks, gychang |
#13 | |
Jeff |
#14 |
I was actually thinking about a protective covering on the kid. Then I don't need to worry about the effect of a grille over my speakers.
pete |
#15 | |
I'm excited that you found success. I may try this again. I'm pretty gun-shy after loosing 4 out of 4, but -- even with the scraping from the black goop at high levels -- the plugs make an improvement. It was clearing up that last scrapping problem that lead to the death of our 127s. I'm glad their death has produced some positive results. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#16 | |
I have modded FE127 in stock & ready to ship. 126s might take a bit longer, i'm working thru the next batch. dave
#17 |
I can vouch for the 126s. Elsewhere I described them as being a bit like a baby version of those modified Decware 206s. They're almost as good as the Sigmas, and probably have an edge in the bass. With plugs in them... I'll have to think about it.
#18 | ||
But I think it's an educational problem. My daughters did touch them only once. After explaining 'em firmly why they shouldn't, they never did it again. The general problem is with my friend child or my daughters friends... I found one solution : the tweeters are soft domes and I have phase plugs in the boomers Quote:
#19 |
There are quite a few threads about popping out a crushed dust cap and I tried some of the suggestions. The dust cap on the FE126 is fairly stiff and wouldn't pull back out with either a vacuum or tape.
I agree on the education point. Both my kids understand that speakers are for listening, not touching. pete |
#20 | |
Hi gychang, At the time I did the dust cap removal, I had only about 150 hours of playing time on them. To my ears the phase plug smoothed out the higher frequencies. It made the speaker easier to listen to. They are in the BIBs right now and sounding pretty good. |
| Singular & Fostex FE206e Phase Plug and EQ Modifications | vdbosch | Full Range | 3 | 16th October 2009 09:43 PM |
| did i blow out my fostex 127e's? | crappyjones123 | Full Range | 8 | 16th July 2009 06:54 AM |
| Fostex 126e or 127e | germpod | Full Range | 71 | 9th May 2008 08:26 PM |
| Fostex FE206E socket phase plug | johninCR | Full Range | 16 | 27th January 2008 11:35 PM |
| Fostex FE206E phase plug | tade | Full Range | 11 | 13th September 2005 12:48 AM |
| Page generated in 0.10994 seconds (86.90% PHP - 13.10% MySQL) with 11 queries |
