Baffles for PVC tube TL speakers? Would it work?
Old 24th October 2006, 11:25 PM   #1
Spasticteapot is offline Spasticteapot  United States
Send a message via AIM to Spasticteapot
Default Baffles for PVC tube TL speakers? Would it work?
For the sake of my sanity, my first speaker project (that should actually work) is a pair of RadioShack 40-1041 FR drivers in a 4" PVC pipe TL.
Rob Samson's PVC pipe design
I know that the bass on these type of TL's is not great, and the midrange can be bad, too. So, what if I added a baffle?
I have some convenient 2'x3' (600mmx900mm) acrylic panels that would be ideal. How would I mount this on the end of my TL to improve the sound?
Old 26th October 2006, 01:39 AM   #2
Anybody?
Old 26th October 2006, 02:05 AM   #3
v-bro is offline v-bro  Netherlands
v-bro's Avatar
I think it would be ugly to say the least...
Maybe you can build a notch-lowpass filter combination to enhance things a bit...
You can connect one between the source and the amp...
I made these for on my bike (see picture), not the best sound, but much better than my sony active speakers....
The version I built with a monacor sp-60/8 has quite stunning bass reproduction! This one I made active with two t-amps each side and a 1" softdome, sold them right away to a friend who had to have them for his car....Have no pics, sorry...
Hope I've been of some help to you...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 26th October 2006, 02:06 AM   #4
v-bro's Avatar
oops:
Old 26th October 2006, 02:07 AM   #5
ocool_15 is offline ocool_15  Canada
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
the baffle will increase the output on higher frequencies mainly when your close to the speaker. Usually referred to as baffle step. Try it but I can't see much difference anywhere else.
You can try an infinite baffle. where you would just use the board.
Old 26th October 2006, 02:29 AM   #6
v-bro's Avatar
They mostly require a lot of eq-ing too....
Old 26th October 2006, 04:01 AM   #7
An oval-shaped baffle will boost the sound from about 100hz to about 3 khz. I think that this should help fix the baffle step loss.
Also, the design will be quite snazzy; I'm using clear acrylic, after all.
Old 26th October 2006, 01:03 PM   #8
Dumbass is offline Dumbass  British Antarctic Territory
This implies that you've tried other projects that don't work?
Old 26th October 2006, 01:16 PM   #9
More accurately, my first project that's being built to proper speaker specs. I've put a speaker driver in a cardboard box, and failed so far in my first two attempts at a Gainclone, but nothing that would constitute a decent listening device.
A piece of 2x4 inside some PVC pipe is pretty simple. Adding a baffle would allow me to adjust for baffle step loss without any messy crossovers.
Old 26th October 2006, 06:02 PM   #10
v-bro's Avatar
You might want to add an extra driver and cabinet and DO very simply filter (first or second order lowpass "pllxo" or "loudspeaker filter") the higher octaves out...
Baffles for PVC tube TL speakers? Would it work?Hide this!Advertise here!
Foam speakers - would they work? Spasticteapot Multi-Way 33 8th January 2007 12:26 AM
Clear acrylic speakers - any ideas? (Also, how should I make B3s open baffles?) Spasticteapot Full Range 17 22nd October 2006 04:19 PM
PC speakers amp runs ac?? Does DC work? NeMeSiS_singh Power Supplies 8 14th June 2006 10:35 AM
Making Two Speakers Work Together MuaDibb Multi-Way 5 29th April 2006 02:16 PM
Can car speakers work in a box? maylar Multi-Way 6 19th January 2004 11:34 AM
Copyright ©1999-2017 diyAudio
