Omnes Audio L8 impressions - diyAudio
Old 24th October 2006, 03:02 PM   #1
inrank is offline inrank  United Kingdom
inrank's Avatar
Default Omnes Audio L8 impressions
i thought i would write a 'basic' review of my new speakers using the Omnes Audio L8 full range driver.
after listening to this for a while, and i guess it has had about 30-40 or so hours running in time, i think either i have got used to the slightly top heavy treble or it has smothened out a bit because it sounds really good now.
i am not sure what i am describing but the mid range, and especially the vocals seem to come out a lot from the speakers and i could swear they were just in front of me, and the actual voices seem very 'live' or real, as if they were in my room not in a padded recording studio.
there is not really any bass (not that i expected any) but seems just right if i am listening late at night and with relaxing music, dont really feel the need for a sub, but i do with louder rock etc.
i do not feel the need for a tweeter although if the treble is a bit to much you could cut it off lower and add a tweeter.
i cant really say much bad about it because for 100 a pair they whip my Kef XQ1's on imaging, dynamics and vocal reproduction (the kefs are better at overall accuracy and bass).
about the actual units, the cone is very stiff and it is very hard to move the cones manually and they hardly move even at ear splitting levels and the woofen phase plug looks very good set against the black cone and the full paper (all-in-one) surround looks very neat.
a rubbish pic of them in my room (obviously they would be aligned for listening )
Old 24th October 2006, 03:15 PM   #2
inrank's Avatar
some more photo's...
Old 25th October 2006, 12:47 AM   #3
Klimon is offline Klimon  Belgium
Good to hear a review of these, the FR looks very linear but that's only a first indication (if it's not too fraudulent as with some other speakers), I'm mostly interested in high-mid and treble smoothness for replacing Beyma 8ag/n that have very similar T/S data but some problems. Are the L8 phase plugs attached to the membrane or mounted on the polepiece (with a narrow gap between plug and speaker membrane)? Most manufacturers just glue them on the cone, fast and easy, neglecting more important issues as cone-mass and a-voiding resonant voids...
Simon
Old 25th October 2006, 10:11 AM   #4
inrank's Avatar
the phase plugs do not move so i assume they are attached directley to the magnet at the back as there is a hole in the rear of the magnet and you can see the back of the wooden phase plug and there is a gap between the phase plug at the front and the voice coil.
Old 25th October 2006, 11:36 AM   #5
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
for more bass mounting them in "das viech" could be an idea?
Old 25th October 2006, 11:46 AM   #6
inrank's Avatar
is than not a horn? and dont the L8's have a too high QTS? (and i am using them with a sub so bass isnt a problem)
Old 25th October 2006, 01:47 PM   #7
Scottmoose's Avatar
Yes, it's a horn, and I can't see this driver working too well in it with a Q of over 1.0. Having said that, Vas is pretty low, so it's not impossible that it could be used (horns do not automatically require low Q drivers) but it would have to be designed around it from scratch.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 25th October 2006, 05:03 PM   #8
GM is offline GM  United States
GM's Avatar
Greets!
FWIW, based on published specs, Professor Leach's math suggests a 61.75 Hz Fc:
Vr = 148.63"^3
St = 42.04"^2
Am = 1891.77"^2
Am (min.) = 945.89"^2
M = 0.857 with an inital 3.54" long straight section and use a horn program to find its expansion length based on desired mouth area.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th October 2006, 06:09 PM   #9
el`Ol is offline el`Ol  Germany
I have been asking myself for a while whether the Viech would work, since TSPs of Omnes an Beyma are very similar. I hope someone will try one day.
Old 25th October 2006, 07:46 PM   #10
Scottmoose's Avatar
Greg -are we talking the 'On the Specifications' paper here? I really should re-read that.
Omnes Audio L8 inrank Full Range 1 31st May 2008 07:48 PM
Omnes audio L8spec - opinion needed barackuda Full Range 3 11th September 2007 11:42 AM
Omnes Audio L8 (UK) inrank Swap Meet 13 9th December 2006 08:27 PM
Efficient sub for Omnes Audio L8's inrank Subwoofers 15 19th October 2006 01:05 PM
OB with Omnes Audio L8 inrank Multi-Way 0 9th August 2006 01:36 PM
Copyright 1999-2017 diyAudio
