TABAQ TL for Tang Band - Page 50 - diyAudio
Old 21st December 2012, 01:51 AM   #491
toobhed is offline toobhed  United States
Hi JHutka,
No, I used the same dimensions for the 4" as Bjorn posted for the 3"....sounds great!
Mario
Old 21st December 2012, 06:34 AM   #492
Hi Bjorn: In India we are starved for speaker drivers but I have found a local manufacturer [http://www.iwaispeakers.com] and they seem to have a promising FR driver which might work well in the TABAQ:
4" Driver
Nominal Impedance 8 Ohms
Resonance Frequency 110 Hz
Power Handling {IEC-268-5C} 25 Watt
Long Term Power {IEC-268-5L} 75 Watt
Short Term Power {IEC-268-5S} 125 Watt
Sensitivity (2.83V/1m) 90 dB
Resistance (DC) 5.5 Ω
Qts 0.81
BL 3.8 T-M
VAS 1.44 Liters
Can I please request you to simulate this and see if this would work in a folded T-L?
Thanks! in advance.
-\keith
Old 21st December 2012, 10:48 AM   #493
4" Driver
Qts 0.81
BL 3.8 T-M
VAS 1.44 Liters
Thanks! in advance.
-\keith
Got revised parameters for the driver from the manufacturer:
Nominal Impedance: 8 Ohms
Resonance Frequency: 100 Hz
Power Handling {IEC-268-5C}: 25 Watt
Long Term Power {IEC-268-5L}: 75 Watt
Short Term Power {IEC-268-5S}: 125 Watt
Sensitivity (2.83V/1m): 88 dB
Resistance (DC): 7.4 Ω
Qms: 2.81
Qes: 0.85
Qts: 0.65
BL: 4.69 T-M
VAS: 3.18 Liters
Old 21st December 2012, 10:56 AM   #494
Hi Keith,
do you have the cone area Sd ? And maybe also Lh (mH).
First impression si that this would work, but I will simulate it.
Hi from
Bjorn
Old 21st December 2012, 11:19 AM   #495
Bjorn: they have not given this on their website but I will mail and ask. Thanks!
Old 22nd December 2012, 09:02 AM   #496
Hi Keith,
I just had a look the freq-range of this driver on the iwai-website. You shouldn't expect too much from it at >8kHz. From the picture and the measures the sd should be around 51-55 cm². To me it looks more like a midwoofer than a fullrange-speaker.
Old 25th December 2012, 10:22 AM   #497
Default IWAI in TABAQ
Hi Keith
I agree with kNOPFLER, this is not a full range driver.
If you put it into TABAQ you will experience a week bass - and no high treble as you can see on the manufactures webpage.
For your information I have attached the simulation of the IWAI driver in TABAQ.
Happay X-mas from
Bjorn
Old 25th December 2012, 12:34 PM   #498
Thanks Bjorn. Merry Christmas to you and all here.
Old 27th December 2012, 05:18 AM   #499
Hi Bjorn:
I got all the measured parameters from the manufacturer. Also some graphs. Have attached them. Do your simulations with this data still show that this may not work well?
In advance, Thanks!
-\keith
File Type: txt TSP Sample #1646-1.txt (779 Bytes, 9 views)
Old 27th December 2012, 09:09 AM   #500
Hi Keith this will not change the sim.
You could try less stuffing - like 70 gram and no baffle step filter.
As you can see the driver frequency is dropping in the high end and would need help from a tweeter.
Build one and see what you think.
Hi from
Bjorn
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
Copyright ©1999-2017 diyAudio
