#31 | |
The overall SPL (sound pressure level) is proportional to the radiating area of the source. I guess the port is smaller than the driver. Than you have to lower the measured curve from the port by Delta=10*log(D port / D driver)^2 dB. For example, say the effective diameter of your 4" TB is 3.5" and the ID of the port is 1.5". Delta = 10*log(1.5*1.5/3.5*3.5)=-7.35 dB. As soon as I wrote this, I started to doubt myself: do we have to multiply by 10 or by 20 here? I would appreciate a correction, if my memory failed me. In any case, another good way of checking it is that at very low frequencies, say below 20 Hz the curves should coinside. Important thing is that you should make these measurements as close as possible to the cone and the terminus of the port (no more than 5mm), and do not change the volume between the two measurements. VadimB |
#32 |
"Important thing is that you should make these measurements as close as possible to the cone and the terminus of the port (no more than 5mm), and do not change the volume between the two measurements."
I did. But then its mathematics for the pro... Now i know why i need that! Keep going VadimB! But dont brag for us stupid. ![]() Learn us with example. Solve
Music is the only art in real time.... |
#33 | |
I actually need your help to do just that. Earlier in this thread, I've posted an alternative design for 3" TB driver and promised to post measurements. I have screen shots from Sound Easy for that speaker, however they are large files with higer resoultuion. No matter what I do, the software of this Forum tells me that "attached file is too large". Can you, please, teach me how to do this? VadimB P.S. If there will be some interest in that design - I'll start a new thread on it. |
#34 |
Sorry! That user has specified that they do not wish to receive emails through this board. If you still wish to send an email to this user, please contact the administrator and they may be able to help.
? I help you when you fix it. Solve Sorry for this mumbo jumbo.
#35 |
Solve,
I just edited my options on the board. It should work now. Thanks, VadimB |
#36 |
Dont work.
try this peter_fors.add.hotmail.com
#37 |
VadimB i cant email you?
Sorry for this folks... Sorry! That user has specified that they do not wish to receive emails through this board. If you still wish to send an email to this user, please contact the administrator and they may be able to help. Solve
#38 |
Solve,
I've just openned all the doors there are on the "options" tab of my prophile. If this does not work, I'll have to contact the administrator. I've sent an e-mail to the address you gave (*.hotmail) last week. Did you get that? Sorry for the bandwidth, folks! VadimB |
#39 |
Didnt get it.
Maybe an dot to much. peter_fors(@)hotmail.com Solve (Sorry for this-have enough of spam)
#40 |
Folks,
I've finally checked the DiAppolito book and, man, was I wrong! The correct formula for correction of port-to-woofer is: Delta (dB) = 20*log(D port / D woofer) Diameters are not squared! So, in the previous example (woofer 3.5", port 1.5"), the correction is: Delta = 20*log(1.5/3.5) = -7.34 dB, so the port near-field response should be lowered by 7.34 dB and then summed with the woofer. Sorry, but it's better late than never... VadimB |
| Tang Band W3-593SF vs. Tang Band W3-926SD | Zaputh | Full Range | 17 | 5th June 2009 11:37 PM |
| Tang Band MTM ? | wrenchone | Multi-Way | 11 | 21st November 2007 06:39 PM |
| 8 x 12 Tang Band | troystg | Subwoofers | 3 | 2nd February 2007 03:37 AM |
| Tang-band 2-way (W3+W8) | haffe | Multi-Way | 10 | 31st January 2007 11:11 PM |
| New Tang Band is BUSTED! | Zero Cool | Subwoofers | 6 | 8th May 2006 04:15 PM |
