TABAQ TL for Tang Band
Old 2nd November 2006, 07:06 PM   #21
Bjohannesen is offline Bjohannesen  Denmark
Hi Solve, glad you like it.
Are you sure yoú used enough damping material ? It is pretty well damped. 100g is a high density for this small volume. I use 200g in my TL sub, which is s much bigger cabinet with a 10" driver.
I have not experienced boomy sound, but I sure did when I tried it with Hi-Vi 3".
Hi from Bjorn
Old 2nd November 2006, 09:44 PM   #22
VadimB is offline VadimB  United States
VadimB's Avatar
Default alternative design
Hi guys!
I've recently built a designed and built a similar speaker for newer TB 3" - W3-1231SH. It was also designed using MJK's worksheets (a little older version). It is a MLTL, built from 1/2" MDF. Front, back and side pieces are 3" wide and 18.5" long. Top and bottom are 3" x 4" and glued on top of the sides. So, the inside dims are 2"x3"x18.5", and external 3"x4"x19.5".
The driver is 6" from the top inside. The port center is 9.5" from the top inside. Port ID is 0.82". The length is 2".
The speakers are designed to actually hang on the wall. I will try to attach the MJK's simulation, the actual Sound Easy measurements, done on the wall and a picture. Not sure if it can be done in one post. If not, I'll put the rest in separate posts.
VadimB
Old 2nd November 2006, 11:03 PM   #23
gychang is offline gychang  United States
Default Re: alternative design
Originally posted by VadimB
Hi guys!
VadimB
like to look at the pics. gychang
Old 3rd November 2006, 02:11 AM   #24
VadimB's Avatar
Sorry,
I could not figure out the way to shrink my pictures to the required 100x100 size, so lets try this:
VadimB
Old 5th November 2006, 07:04 PM   #25
Solve is offline Solve  Sweden
Solve's Avatar
I got my W4-1320SA and smacked them in.
What could i say?
Woooaahhh!
There the bottom comes that i want!!
Sounds very good!
Solve
Music is the only art in real time....
Old 8th November 2006, 09:25 AM   #26
Solve's Avatar
First of all, i dont have much experiance of measuring speakers
but i did an very basic try.
Im using an uncalibrated Panasonic WM-61A with my computer
and an StValue 24bit soundcard(Envy24 chip).
Software Tombstone running an sweep 20-20khz with
W4-1320SAwith BSC 0,8mH+3,9ohm.
First one is with modded T-amp.
Red line is port.
Old 8th November 2006, 09:37 AM   #27
Solve's Avatar
This one is with my Marantz PM-30.
There i can see that nasty peak at 7khz.
Cant see it in T-amp?
Why?
Old 8th November 2006, 09:39 AM   #28
Solve's Avatar
This is T-amp,1 meter. centered at cone.
Old 8th November 2006, 01:22 PM   #29
VadimB's Avatar
Default Measurements
Solve,
In your first measurement with T-amp, there is a message at the left bottom corner of the screen: "Input overloaded". That's, probably, what is responsible for a ruller-flat curve at 0dB. Your later data do not have this message, so they are much more realistic. If the first one was a near-field measurement, just lower the volume until the curve is lower than 0dB and has some wiggles. You can only trust near-field up to, maybe, 1kHz at the most. Also, if you want to add this data to the port output, do not forget to scale the port data by the ratio of port diamenter to driver diameter squared. Than you can splice that to the 1 meter data. Still, this will not account for difraction effects (baffle step).
The single best book on how to measure speakers properly is Joe DiAppolito's "Testing Loudspeakers", available from Audio Express.
VadimB
Old 8th November 2006, 04:06 PM   #30
Solve's Avatar
You have an good eye VadimB!
Didnt see that.In tombstone you get an pop up screen that say the same so i trusted that...
But you are right, it was to good!
Now we see that ugly 7khz peak.
How do i notch that?
"Also, if you want to add this data to the port output, do not forget to scale the port data by the ratio of port diamenter to driver diameter squared."
How do i do that?
Now i just moved the mic without changing the volume.
Think i have to get that book.
Solve
TABAQ TL for Tang BandHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
