TABAQ TL for Tang Band
Old 6th March 2012, 12:38 PM   #271
Milus is offline Milus
Looks gorgeous, can't get my eyes off it!
Wouldn't it use a stand to have the driver a bit higher?
Old 6th March 2012, 08:00 PM   #272
Bjohannesen is offline Bjohannesen  Denmark
The acryl was no problem. I got it cut for about 35 $ (calculated from Danish Kroner) and it came with a protection film.
The speaker can be on a stand, on a shelf or just be mounted on the wall with the opening down.
Old 6th March 2012, 08:05 PM   #273
chrisb is offline chrisb
Originally Posted by Scottmoose View Post
Love the acryllic. Often wondered about using that. Well, getting someone else to, as I can't build cabinets. Not well, anyway. No facilities. Or time. Or talent...
mate - speaking from experience any hack can build a simple cabinet - it takes time and talent to design one that sounds good and is simple for us hackers to build
like my mind, this space intentionally blank
Old 6th March 2012, 09:50 PM   #274
Mike514ml is offline Mike514ml  United States
The acrylic sides are gorgeous, and it sure beats filling, sanding, priming, lacquering, sanding some more, lacquering again, sanding again, letting it sit for a couple of weeks, clear lacquering, letting it sit for a month, sanding, rubbing out the finish, rubbing out the finish, rubbing out the finish, etc. Piano black in one easy step!
Old 11th March 2012, 01:57 PM   #275
bAD kLOPFER is offline bAD kLOPFER  Germany
I did some more measuring and simulated some correction circuits in Boxsim.
Attached are the frequency responses under different angles (and at my preferred listening position "Hörplatz")
and the last version of the simulated correction circuit. Suggestions concerning the circuit are welcome as I'm
a rookie in this item .
Sven
Old 11th March 2012, 02:36 PM   #276
kristleifur is offline kristleifur  Iceland
Sven
Can't comment technically as I'm even more of a rookie, so: Good work, and quite inspiring. Thanks for posting.
Old 19th March 2012, 07:36 PM   #277
So, I ended with the attached correction circuit and the corresponding measurement. I think the speaker performs quite well .
Old 26th March 2012, 05:34 PM   #278
zman01 is offline zman01  Bangladesh
Originally Posted by Bjohannesen View Post
Hi Sven, nice work !
I have finished my folded TABAQ BOX, and it is doing very well down to 45 Hz. It is really amazing what you can get out of this small driver.
TABQ BOX can be placed in any direction as long as the opening is not blocked.
The cabinet is made by 12 mm MDF, except the sides which is 9 mm plywood and 3 mm black acryl. Looks very nice according to my wife.
Which driver are you using in this particular build?
Old 26th March 2012, 05:50 PM   #279
It is Tang Band W3-315SC which i used in the first TABAQ. These cabinets has been "upgrated" to W4-1320SA.
Both 3" and 4" can be used in TABAQ and TABAQ BOX without any changes.
Old 26th March 2012, 06:08 PM   #280
I have a pair of 3" TB drivers with the following specs:
Frequency range: 100-18,000 Hz
Fs: 100 Hz
SPL: 85 dB 1W/1m
Vas: 0.04 cu. ft.
Qms: 4.77
Qes: 0.72
Qts: 0.62
Xmax: 1.5 mm
Impedance: 8 ohms
Re: 5.98 ohms
Le: 0.44 mH
Thinking of bookshelf type design - a folded Tabaq might work?- How tall is the folded cab?
Thx.
TABAQ TL for Tang BandHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
