TABAQ TL for Tang Band
Old 15th January 2018, 01:47 AM   #2051
albertli is offline albertli  Canada
albertli's Avatar
Originally Posted by perceval View Post
nice looking. Can we see the impulse as well?
So, that's with the TC9 on top and open back?
I have to learn to do this. Give me some time and I'll figure out.
It sounds to my taste now. Give them some time and they will shine.
Thanks Bjorn again for sharing such a good design. The two pair of drivers sit doing nothing without this design.
Old 16th January 2018, 01:01 PM   #2052
perceval is offline perceval  Taiwan
perceval's Avatar
Bjørn, if you are listening...
I know we kinda dismissed the W5-2143 earlier, with its low Qts.
I don't have MJK's papers to sim this driver, but I gave a shot with LeonardAudio app and it doesn't look too bad!
So, maybe it could be a good candidate.
Old 16th January 2018, 05:05 PM   #2053
Bjohannesen is offline Bjohannesen  Denmark
I have not made any sims, but it will be possible to design a good QW around this driver.
Bjørn
http://www.kvart-bolge.com/
Old 17th January 2018, 10:45 AM   #2054
krakatoa is offline krakatoa  Romania
krakatoa's Avatar
Actually it's not that simple, because I know of two different measurements and they are not identical to the published specs:
Qts=0.45 - by user XRK871 - Decware DNA Horn
Qts=0.65 - TB SPEAKERS W5-2143 (Full-range 5", 8 Ohm, 60 Wmax) (image located in the lower part)
After playing around with the different data sets I realized it will be a 30-40 liter enclosure tuned in the 46-55 hz interval... maybe a little higher if that Fs is really above 80hz. The reviews report a disappointing bas performance with bas reflex enclosures but no bad word from TL designs, in fact I believe I found a japanese source that reported excessive bas from a TL (note:google translate is not perfect).
I believe tuning higher is the right strategy for this driver, in the sense not to push it as low as possible, the rest is TL magic as you go lower plus the Sd is much larger than a 3 incher or a 4 incher (Sd=92cm2 - measured by me with 1/2 surround minus phaseplug).
Old 17th January 2018, 01:21 PM   #2055
perceval's Avatar
Hmm... now, that's some disparity between measurements.
My TB 4" were not that far off... but the Visaton B80 were.
I guess we could take a chance and pick the middle ground which would be X's measurements... until I get myself a pair, if I ever decide on a 5" driver.
Old 17th January 2018, 01:36 PM   #2056
krakatoa's Avatar
The TABAQ large for W5 1611 is about 34 liter in volume but tuned lower (if I remember correctly)... ideally you make an enclosure where the small tube (terminus, not the column) length is adjustable and you can play around until it sounds right.
Old 17th January 2018, 01:41 PM   #2057
perceval's Avatar
I took a few minutes to try a couple of things and I didn't like it so much in a QW... hmmm... back to driver hunting then. Or back to the 1611.
Old 18th January 2018, 05:07 PM   #2058
janmar is offline janmar
Dear all.
I´m still considering the MTM version of TABAQ enclosure. I would like to simulate this option in LeonardAudio app. However, I do not know how to adjust/mulitply W4-1320sj specs in that app.
Could you offer me advise?
Considered X-over frq is 8kHz.
Jan
Old 18th January 2018, 10:05 PM   #2059
Jerms is offline Jerms  United Kingdom
Originally Posted by janmar View Post
Dear all.
Jan
Martin King has a page or doc somewhere showing how to do this. (Now I can't find it though ). Simplistically, the CSA is doubled "everywhere". That includes the port.
Old 19th January 2018, 12:44 AM   #2060
perceval's Avatar
Dear all.
Jan
Like Jerms said, and if you don't want to double the enclosure, you could go with the last TM in a sealed enclosure on top. That would make it a 3-way.
TABAQ TL for Tang BandHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
