TABAQ TL for Tang Band
Old 5th November 2017, 02:09 PM   #1921
Bjohannesen is offline Bjohannesen  Denmark
Default TB W4-1879
Hi
I would use this driver in a Quarter Wave.
In MJK┤s sim the "infinite baffle" shows a drop from 300 Hz, leaving very little to work with in a Quarter Wave design.
You do not see this drop in the SPL plot on Tang Band┤s homepage, but you can see there is a little less bass than you would expect looking at driver Fs and Qts.
I tried different designs, adjusting tuning frequency, volume, stuffing etc.
I even checked different sources to be sure the T/S parameters where correct.
It might be useful in other designs. However, this is not a driver I would choose in "my design world".
Hi
Bj°rn
http://www.kvart-bolge.com/
Old 9th November 2017, 11:54 AM   #1922
astoinov is offline astoinov  Bulgaria
Hi guys,
I am writing here to share some of my experience with my first TABAQ build (with Monacor SPX-30M). A couple of posts ago I wrote that I have a peak in the mids that is covering the bass a bit. I haven't tried the BSC filter yet but I tried EQ-ing a bit. If I attenuate the frequencies above 700Hz with 3-4 db the sound gets muffled but I found out that if I just make a notch at 700Hz the sound gets a lot better for my ears. I will show you the EQ later, because that's on my home PC. Maybe I am getting used to the sound of the speakers or they are burning in, I don't know, but now the low frequencies are there and I pretty much like the sound. They sound pretty balanced and punchy.
So if someone is considering to try the TABAQs with these exact speakers - I hope this information is of any help to you.
Maybe the Tang-bands sound much better but these Monacors are very very cheap here in Bulgaria (around 12-13 euros a piece).
Old 9th November 2017, 04:47 PM   #1923
janmar is offline janmar
Default W4-1879
Originally Posted by Bjohannesen View Post
Hi
Hi
Bj°rn
Hi Bj°rn.
Thanks a lot for you survey.
.....if the adoption of more expensive driver into TABAQ does not bring the reasonable results I am fine with the 1320sj....
ATB
jan
Old 17th November 2017, 03:23 PM   #1924
burgunder is offline burgunder  Denmark
I wonder if this will fit in the large Tabaq FaitalPRO | LF Loudspeakers | 5FE120
Old 17th November 2017, 10:50 PM   #1925
perceval is online now perceval  Taiwan
perceval's Avatar
Are you planning to add a tweeter?
The 5FE120 barely reaches 5kHz...
Old 18th November 2017, 06:57 AM   #1926
Yes it will need a tweeter.
Old 27th November 2017, 05:10 AM   #1927
dasroot is offline dasroot  United States
Hello,
Working on a set of the TABAQ LG with the W5-1611SAF. These are exactly to the dimensions in the plans that Bjorn so awesomely put together. I have a couple of questions if anyone has time:
1) The BSC I have calculated is 1mH and 3.5 Ohms in parallel. Is this too far off?
2) Has anyone augmented the plans for the Scanspeak 10F/8414G-10? And if so what about 2, in a MTM design?
Once again, any help is greatly appreciated. I did some googling but couldn't seem to find the answers.
Old 27th November 2017, 07:16 AM   #1928
perceval's Avatar
1- sounds good, but it will depend on your room and placement near or far the wall behind the speakers.
2- 10F should do fine in the original TABAQ. MTM much more difficult because drivers need to be placed very close together... but not impossible with a little imagination and trickery!
Old 27th November 2017, 10:18 AM   #1929
Good answer Perceval!
Old 27th November 2017, 08:09 PM   #1930
CER2906 is offline CER2906  England
Default CHR 70.3 Tabaq
Hi all,
I am finally putting my Mark Audio driven Tabaq's together and have had a change of plan with regard to the port.
I am thinking of making a downward firing port with a tube. I would of course raise the cabinet on some feet.
I have seen Bjorn's test enclosure in a previous post (#1507)
My question is, can I put the tube fully inside the enclosure or would this mess up the tuning of the cabinet?
Any advice is appreciated.
Chris
TABAQ TL for Tang BandHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
