TABAQ TL for Tang Band
Old 10th September 2008, 12:10 PM   #141
jrz_stoichkov is offline jrz_stoichkov  Finland
A picture from my 871s version. A bit different geometry and an option for cabinet changes (opening back board). Standard 80mm computer fan grill preventing mechanic hazard (three 1-4 yrs sons) of drivers.
[img]http://venda.uku.fi/~jleskine/TBQ/Ta..._port_sml.jpeg[/img]
Old 2nd October 2008, 02:33 AM   #142
Ang is offline Ang  United States
I've got 4 of the TB w4 1320sc's and some cheap dayton tweeters - was thinking I could use the second woofer as a .5 to compensate for baffle step in the tabaq.
Is there an optimal way to calculate the crossover for this? (or put it into MJK's spreadsheets?) Thanks!
Old 2nd October 2008, 06:30 PM   #143
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
measuring is the best way, but if you do not have the gear, I suggest the program "the edge" to simulate bs
Old 2nd October 2008, 07:39 PM   #144
so I should essentially have the .5 woofer come in at the mid point of the Baffle step compensation dip in the Edge?
Old 24th February 2009, 11:37 PM   #145
ltmon is offline ltmon  Australia
A 4" TABAQ, using the W4-1052SD.
Currently it's running without BSC filter, but I think I might add one and possibly later try out a tweeter. Would love to hear how your's pans out Ang.
Thanks for the design, based just on what I hear I think it's really worked out well with these drivers.
Old 25th February 2009, 02:49 AM   #146
Apparently my attachment didn't work, let's try again...
Old 25th February 2009, 07:45 AM   #147
Nice looking speaker there.
Currently have wood cut for the design, will post results. Have great plans for a granite baffle, which hopefully works out.
Old 25th February 2009, 01:59 PM   #148
rco3 is offline rco3  United States
Eventually, I got around to building my "folded Tabaqs" which ended up being more or less NOT Tabaqs. I just had to have a tweeter. Heresy, I know, I'm in the full-range forum and everything, but a 4" FR just gets kind of beamy. Sorry. So I explored various tweeters, etc., and then decided to just match the stuff currently in my main system - Zaph's Bargain Minis. It's a 4" MCM 55-3853, relatively similar specs to the W4-1320 in my Tabaqs. I spent some time with MJK's worksheets (before my 1-year limit ran out) and iterated to a folded, tapered line that looked good.
So I built these cabs:
Folded, tapered, longer than TABAQ and a two-way. (I guess I'm officially off-topic.) I'm rather fond of the way that the port (now a tube) extends from the bottom of the line through the top of the line and out the front of the cabinet. I used Zaph's drivers, crossover, and driver spacing verbatim, with a slightly narrower front baffle. I'll get around to adjusting baffle step someday, but it's hard to take 'em down because they sound nice.
It's hard to think of these as a final revision; the height is awkward, in between a floorstander and a standmounter. They'd make a great pair of dorm speakers or bedroom speakers, I think, because of the tiny footprint. I have no measurements, yet. Too busy listening to these and building others.
Old 26th February 2009, 03:30 AM   #149
jackpipe is offline jackpipe  United Kingdom
Default TABAQ in marble
Yay, I've just completed a single TABAQ speaker in 18mm black marble, using TB-871SC. Not stuffed properly or completely sealed yet, but already sounds great, and of course looks fantastic. Will post pics imminently.
For the first one, I just followed the standard design, modified for 18mm thickness, and rounded the front edges. I think I will alter the design for the second one, so that the front is a continuous sheet, with the joins on the sides, or use diagonal joins, etc.
Old 4th March 2009, 02:01 AM   #150
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Wait a minute... marble??? I salute you sir!
Where'd you source it? How much if you don't mind me asking did it cost ya?
Wherever you go there you are.
TABAQ TL for Tang BandHide this!Advertise here!
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 06:39 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Tang-band 2-way (W3+W8) haffe Multi-Way 10 31st January 2007 11:11 PM
New Tang Band is BUSTED! Zero Cool Subwoofers 6 8th May 2006 04:15 PM
