ML-TL or ML-TQWT with very low Qt driver
Old 25th September 2006, 10:01 AM   #1
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default ML-TL or ML-TQWT with very low Qt driver
I think of making a TL of some sort for a driver with a very low Qt (0.14), what type of design suits best for this?
Old 25th September 2006, 12:29 PM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
A horn, unless you want to run active Eq, or you don't mind a hefty set of values in the correction circuit. Try a BIB with the dimensions I suggested for the FE166E. Jeff's site has these up: www.zillaspeak.com/bib.asp Look in the Fostex category.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 25th September 2006, 12:53 PM   #3
Henkjan's Avatar
mmm, so either big or big....
Old 25th September 2006, 03:19 PM   #4
Scottmoose's Avatar
Bigger is better.
Unfortunately, as GM so often points out, no free lunches in audio. I can do a set of dimensions for a resonant MLTL or ML TQWT for you, but you'll need a wad of series resistance or active Eq to bring it into line or the response is going to rocket (and that's not including BSC). Whether that's important to you or not will depend on the rest of your system, and your room -in a large room, dynamics will start to suffer a bit. I love ML TQWTs and MLTLs -I've build loads of the things, some of which are among the best speakers I've heard. But you're always better off, IMO, choose the right sort of enclosure for the job, rather than to force things. As a general rule, I try to set myself a 0.20 Qt limit these days -lower than that, and though you can still use it, it will usually be better off in a horn.
Old 26th September 2006, 12:15 AM   #5
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
might note that, the lower the qt, the lower the distortion
eye candy-
http://img61.imageshack.us/my.php?image=altecva2.jpg
Old 26th September 2006, 10:15 PM   #6
Henkjan's Avatar
Originally posted by Scottmoose
Bigger is better.
Unfortunately, as GM so often points out, no free lunches in audio......
not looking for that, just a decent performance in a neat floorstander with good WAF; I'll fire up a sub for decent bass.
as monitor this driver performs well in a 8 liter BR, so suppose I give it 20liters in a floorstanding TL? f3=50? it's only a 7", no miracles expeced nor required.
Old 29th September 2006, 03:29 PM   #7
badman is offline badman  United States
badman's Avatar
eye candy-
Nice eye candy
Is it proven that lower Qt is lower distortion? Or just a guideline correlated to effective motor coupling?
Don't get me wrong, I tend to prefer low-q drivers, but can you quantify your statement?
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
ML-TL or ML-TQWT with very low Qt driverHide this!Advertise here!
ml tqwt with unknown driver stevodude Full Range 21 24th January 2016 06:13 AM
Vas and TQWT mahleriana Full Range 12 28th November 2007 01:38 PM
El W-3 871S is a god driver in TQWT? Jaime Full Range 1 19th May 2006 05:33 PM
Building Martin King's ML TQWT... advice on driver subsitutions santiu Full Range 5 23rd September 2005 06:13 PM
What is the Q of a (ML)-TQWT, (ML)-TML, etc Elam Full Range 0 18th June 2005 09:56 AM
Copyright ©1999-2017 diyAudio
