Needles with 2 FRS8 drivers
Old 10th September 2006, 10:41 AM   #1
TDLofCC is offline TDLofCC  Netherlands
Default Needles with 2 FRS8 drivers
Hi ... I recently made two needles with the Visaton FRS8 drivers.
I really love the sound these $10 drivers produce.
Now I wanted to make 4, for the 4.1 (sub is almost ready too ), but I found that my little daughter isn't that carefull ...
So I have 2 bookshelf speakers as rears, which will do for now.
I now have 2 FRS8 drivers left. And since I'm not really happy with the finish on the first Needles, I'd like to remake them.
Would it be possible to use 2 FRS8 drivers in 1 needle speaker ?
If so, what would I need to change ?
Any help would be greatly appreciated.
TDL.
Old 10th September 2006, 10:47 AM   #2
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
my 1st respons would be double the depth of the speaker (so double cross section with same baffle) and filter the 2nd unit with a coil to make it a 1 way speaker.
Old 10th September 2006, 11:02 AM   #3
Ok ... thats out of the question I guess.
They're already 20cm long. Then they'd have to be 40cm long.
I've been searching some more, and I found some pictures of needles with two drivers, one in the front and one in the back. At the same heights ... but ... come to think of it ... they were twice the original height.
So, correct me if I'm wrong, but adding another driver means doubling something of the original design ... height, depth or lenght.
Is it possible to just make all the dimensions a bit bigger ?
On a sidenote ... would it be worth the effort ?
Old 10th September 2006, 11:17 AM   #4
R.I.P.
You can mount them front and back as bipoles to use away from walls.
Theorectically you should double the internal cross sectional area, but
this depends on the CSA to driver CSA ratio you are already using, if
you are definetely rebuilding the cabs you can try 2 in your old cabs.
There is no reason why a bipole cannot be folded.
You could increase internal width to say 13cm and depth to say 30cm.
Effort ? 6dB more maximum output, 6dB more bass when used as
a bipole or 1.5way compared to the mid/treble level, 4 ohm load.
/sreten.
Old 10th September 2006, 02:16 PM   #5
Alright ... only problem is ... they are close to a wall next to the TV.
I'll just have to test them with the needles I got
Nice new project ... and not that hard to make.
Just make another hole in the back and wire the driver to the existing terminal ... I think
I'll keep you posted.
Old 10th September 2006, 02:23 PM   #6
Henkjan's Avatar
do you have the 4 or 8ohm version of the FRS8?
Old 10th September 2006, 08:22 PM   #7
8 ohm version. why ?
Old 10th September 2006, 08:30 PM   #8
Henkjan's Avatar
with 2 4ohm in paralel (so 2ohm load) your amp would probably not enjoy it....
Old 10th September 2006, 10:12 PM   #9
Jim Griffin is offline Jim Griffin  United States
Let me add to one of the statements that Sreten made. The statement was:
"Effort ? 6dB more maximum output, 6dB more bass when used as a bipole or 1.5way compared to the mid/treble level, 4 ohm load."
He is assuming two 8 ohms drivers which are connected in parallel in either a bipole or 1.5 way configuration. In the bass to mid region (typically from the baffle step compensation point and downward), you will have up to 6 dB more output vs. the mid/treble level as he says. Now 3 db of that 6 dB comes from the added acoustical efficiency (dual cones and sound field overlap) and 3 dB which comes from impedance sensitivity improvement (8 ohms to 4 ohms). Now above the BSC point any sensitivity improvement is solely due to impedance sensitivity increase. This results in 3 dB more sensitivity than a single driver monopulse raidator. In this case (above the BSC point) the sound fields radiated by the drivers on the front and rear of the bipole pair don't have any acoustical overlap so no acoustical efficiency increase results. Essentially, you get the same thing for the 1.5 way configuration you have the same output above the BSC point as the bipole assuming that you account for the baffle step with the 0.5 way driver.
Old 11th September 2006, 08:43 AM   #10
Wow ... that kinda of went OVER my head there ...
English is nog my first language ... so thats making it even harder
So, if Henkjan would care to translate it to dutch ... I might be able to understand it ...
Needles with 2 FRS8 driversHide this!Advertise here!
Visaton FRS8 8ohm or 4ohm to choose? hellmis Full Range 9 2nd July 2007 03:38 AM
can i use needles? ACQUA Full Range 3 23rd October 2006 02:22 PM
tubes n needles silurato Tubes / Valves 6 22nd June 2005 05:03 AM
Visaton FRS8 line array & W170S Miha Multi-Way 16 3rd November 2004 11:24 PM
Linus 2 vs needles ? Branwell Multi-Way 0 4th October 2003 01:36 AM
