When using both a parallel notch filter and a zobel filter, is it critical which comes first in the chain?
I've been using a zobel for a little while now but I can't hear any difference when I insert a 50µF cap + 7ohms resistor or the standard (textbook value for the claimed self-inductance of beyma 8ag/n) 10µ + 7ohms. I thought it was possible to 'over-compensate' but my ears don't agree, unless the notch is screwing the zobel performance up The amp is a triode-strapped el84 se. And another one: does anyone know a different method to calculate zobels; I've come accross a zobel for Beyma 8ag/n that uses 4,7µF + 22ohms ????? I can only find equations that recommend the measured DC resistance of the drivers for the resistor value... Now we're at it : is DCR of a parallel notch filter coil critical?Muchas gracias Simon |
#2 | ||
A zobel that is intended to equalise the driver's impedance should go closest to the driver. Quote:
OTOH, it does make the circuit behave differently below the resonance frequency as the DCR is in series with the driver. It is just as desirable to use a low DCR inductor here as with any time you use a series inductor, IMO. |
#3 | ||
Cheers, Simon |
| Zobel network, notch filters and ... a lot of confusion | teodorom | Multi-Way | 11 | 30th August 2010 03:29 PM |
| Question about Zobel/Series notch filter | silentwf | Parts | 5 | 28th November 2007 04:04 PM |
| Disadvantages of using Zobel and Series notch filter ? | percy | Tubes / Valves | 3 | 24th June 2007 11:53 AM |
| zobel network and series notch filter | djmann02 | Multi-Way | 1 | 9th January 2006 12:06 PM |
| Zobel and Notch query | Mos Fetish | Multi-Way | 3 | 8th July 2003 11:36 AM |
