The Metronome
The Metronome
Old 21st August 2017, 10:43 PM   #1481
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The Metronome
All the sims Scott did were in Martin's sheets, but any TL Modeler should do. The approximation is close enuff that one can just model an ML-V (ML-TQWT).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd August 2017, 06:13 AM   #1482
GM is offline GM  United States
GM's Avatar
Here's a Scottmoose Alpair 7P Metronome in Hornresp that can be easily manipulated using the Loudspeaker Wizard:
GM
File Type: txt Alpair7pMetro_SM.txt (972 Bytes, 86 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th October 2017, 12:34 PM   #1483
AmadeusMozart is offline AmadeusMozart  New Zealand
It must be a record - this thread still going after all these years. I've seen plans for the bipole FE126e(n) and wonder if anyone built those and what the feedback is. Similarly I wonder if anyone made a bipole with the FE103E(n).
Thanks, AM.
Retired and enjoying life - I'll only be around on rare occasions.
Old 13th October 2017, 09:52 PM   #1484
mightym is offline mightym  United States
mightym's Avatar
Location: Checotah, Okrahoma former home of the Okra Fest
dave
Thanks Dave,
I don't know how I missed the reply back on August... I just got E Mail notification today on the latest post, and saw your answer.
I have an ML-TQWT simulator I can use.
John
Old 17th January 2018, 06:16 PM   #1485
yildiray35 is offline yildiray35  Turkey
Hi Friends , i like Metronome project. It's look like very eays for building and it's looking very nice. I have got a pair Fostex fe167e drivers on bass reflex cabinet. I want build a metronome and i read 30 page on this topic and i will continiue to read. I find metronome plan for FE167e on Dave web site. ( http://p10hifi.net/FH/download/metro...67-1v0-map.pdf ). But i don'd find measures of the top section and port. My other question : Will i use any insulating material on the inner surface? Thanks to everyone and best regards.
Yildiray
Old 17th January 2018, 08:40 PM   #1486
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
yildray35,
Checking my notes from when I built an FE167e Met 8 or 9 years ago, I used:
port Dia = 3"
port L = 2"
cabinet dimensions:
internal height = 60"
Z(driver) = 30"
S(0) = 4" x 2.5"
S(L) = 10" x 7"
Cover ONLY the BACK interior surface with felt or acoustic foam; IIRC, I used foam; probably 1.5" egg-crate style foam, but I'm not sure.
I did use BSC; 0.7 mH and 1.5 R; but this will depend on your preferences and room conditions.
Cheers, Jim
A day without music is like a day without food.
Old 18th January 2018, 06:06 AM   #1487
Originally Posted by Jim Shearer View Post
yildray35,
port Dia = 3"
port L = 2"
cabinet dimensions:
Z(driver) = 30"
S(0) = 4" x 2.5"
S(L) = 10" x 7"
Cheers, Jim
Thanks my friend! Now I clarified in my head.
Cheers!
Old 21st July 2018, 08:12 PM   #1488
Sarchi is online now Sarchi  Canada
Sarchi's Avatar
I hope nobody minds if I bump this up with a dumb question . I've read about 30 pages of this topic but far from all of it.
I'm building the FE127e Metronome, and the plan shows a 2" radius port (terminus). My question is, should I cut a 2" hole, in which case the tube's inner diameter will be 1.5 - 1.75"? Or is it the inner diameter of the tube that has to be 2"?
Old 21st July 2018, 08:23 PM   #1489
frugal-phile(tm)
planet10's Avatar
The Metronome
Inner diameter is 2”. You can use commonly available plumbing pipe.
If you need to change the diameter: http://p10hifi.net/FAL/downloads/ChangingPortSize.pdf
dave
Old Yesterday, 12:34 AM   #1490
jackinnj is offline jackinnj  United States
jackinnj's Avatar
The Metronome
@sarchi -- from the picture i am wondering if you have lost the terminal 2 digits from the fingers on your hand -- i used to work in a die casting factory where some of the punch press operators were similarly afflicted.
The MetronomeHide this!Advertise here!
A11 Metronome possible? tigh4life Full Range 1 12th July 2011 07:17 PM
