The Metronome
The Metronome
Old 29th April 2013, 09:10 PM   #1051
Jim Shearer is offline Jim Shearer  United States
Jim Shearer's Avatar
Originally Posted by planet10 View Post
Thinking of a compromise between getting bass and good efficiency, you might consider the Fostex FF125wk
dave
+1!! If for some reason you really don't want to use the FF125wk (which would surprise me), then you could look at the FF105wk or the FE103en.
Cheers, Jim
A day without music is like a day without food.
Old 30th April 2013, 12:47 AM   #1052
tnargs is offline tnargs  Australia
Many thanks to Jim for your advice on using my FE 103S drivers.
I can hear the table saw warming up as I type!
Old 30th April 2013, 05:02 AM   #1053
vitorio is offline vitorio  Spain
Dave, Jim thank you for your help.
It looks I must order some ff125wk
Cheers, Victor
Old 30th April 2013, 07:39 AM   #1054
hajj is offline hajj  Lebanon
hajj's Avatar
For the FF125wk, I really advise to do the glue mod at the back of the driver (zig two-way glue is applied to the back of the driver where the surround meet the cone), the one Planet10 uses, helps tame the driver's sibillance (a 7khz peak that can make it unlistenable).
Should you be inclined to go all out on the EnAbl process, all the better
Old 1st May 2013, 12:33 AM   #1055
ssportclay is offline ssportclay  United States
Cheers, Victor
Interestingly, AmadeusMozart built a Met for the FF125WK and FF105WK. It seemed he may have slightly preferred the FF105WK but it was probably a close call. Look back at around 101.
Old 1st May 2013, 10:17 AM   #1056
thoglette is offline thoglette  Australia
thoglette's Avatar
Originally Posted by thoglette View Post
I have the same drivers and was sure I found the sizes in this thread somewhere.
I'm on the road right now but will check my records when I get home
Sorry, mind fade.
I have Fostex FE108EΣ for which I have metronome drawings by Steve Cresswell (with input by D Dlugos & S Lindgren) dated 31-August-06 / updated 28-august-2007
Old 22nd May 2013, 06:55 AM   #1057
I have a pair of original Philips AD9710M full range 8" drivers with the unusual Ticonal magnet material. They look like they would deliver OK bass, although the treble is a bit ragged. Would it will need a uniquely sized cabinet, or will it be close enough to one of the existing Metronome cabinets that have been calculated for other 8" drive units?
I know Gentleman Jim Shearer has been looking into this topic, and I hope he can contribute.
cheers all
Old 22nd May 2013, 07:14 AM   #1058
GM is offline GM  United States
GM's Avatar
Measured specs?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd May 2013, 07:17 AM   #1059
over here
Old 22nd May 2013, 07:39 AM   #1060
GM's Avatar
OK, is there an existing design regardless of driver size that's at least 184-200 L?
GM
The MetronomeHide this!Advertise here!
A11 Metronome possible? tigh4life Full Range 1 12th July 2011 08:17 PM
