Old 25th August 2006, 09:56 AM   #1
Send a message via ICQ to Mikael Abdellah Send a message via MSN to Mikael Abdellah
Default Multiple notch filters?
I would like to correct a rather large hump in the freq range of a wide range driver. I need to loose about 15dB around 3kHz. Is it possible to wire 5 pcs of parallel notch filter in series???
Old 25th August 2006, 01:12 PM   #2
badman is offline badman  United States
Custom Title
badman's Avatar
Yes, if you wanted to have a 15dB notch filter, you could do 5 in series, but they wouldn't simply sum the way you're hoping.
Better is to notch it out line level, for such a dramatic notch. This will take some calculation (or a high-resolution equalizer).
If you must do it speaker level, you would probably have to do a multiple component filter.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 25th August 2006, 05:09 PM   #3
I was afraid/hoping an active crossover would be the best way. I will try to find some information and formulas on the subject.
Active notch filters neutron7 Full Range 2 19th November 2006 11:51 AM
Room EQ notch filters with delay? MBK Multi-Way 9 1st October 2005 03:48 PM
Help on series notch filters. bowdown Multi-Way 1 9th March 2005 05:51 AM
Page generated in 0.07410 seconds (67.53% PHP - 32.47% MySQL) with 10 queries
