Can someone help me figure out what the difference is between the Tang Band Bamboo W4-1320sb and the other TB 4 inchers. Let's use the W4-616s for this example. What in the specs or the design lets the 1320 reach 20khz while the 616s can only go to 14Khz? The cone shape looks the same. The Diameter is the same. Even the phaseplug s look the same. Could it really be the addition of "Bamboo" in the paper?
Here's a link to both: W4-1320sb: http://www.partsexpress.com/pe/showd...number=264-846 W4-616s: http://www.partsexpress.com/pe/showd...number=264-818 |
#2 |
The 1320 does have less mass, so it has more efficiency while giving up a bit at low end.
I have tried the 616. Good low end, but I didn't like the high end. I suspect the 1320 is much better, but I have not tried it yet. |
#3 |
It is said that some people like the low end sound from natural magnets. I have not compared though, but it might have something to do with fux modulation in the different magnet types.
Hear the real thing! |
#4 |
I own both drivers. The 616 has decent bottom and mid, but it is very different than the 1320. I use the 616 as dummy and test loads, and use the 1320's for critical near field listening. Bamboo in cone. You might want to look at Godzilla sit for the BIB boxes. I have tried it, but look intresting.
Chris |
#5 |
While TB drivers may MEASURE full range, they cannot be used full range IMHO.
The 616 has nasty breakup modes around 6 and 12kHz which are audible. Bamboo has rising FR which sounded unpleasantly bright to me. So I'd recommend 2-way with x-over around 3kHz. YMMV |
#6 | |
So in comparing the 2 drivers, do you feel that the 616s is missing some high frequency information or is it just that the 1320 sounds better over all? |
#7 | |
#8 |
Some time ago, one of the crossovers came unglued from inside one of my two-way mains, and so the only alternative was a pair of single-driver vented bookshelves with the W4-616. Before then, they had been doing surround duty in a home theater set. So I swapped them out, and began noticing the things that single driver enthusiasts always rave about (no audible crossover points, amazing imaging). But I did notice that they were missing the top end sparkle that I had found so satisfying from my two-ways. They did have some air to them. I'm sure with a little bit of filter work, they would be a good-sounding driver for the enthusiast who is just starting with single-driver loudspeakers. I eventually repaired my two-ways, and went back to them, but I still remember my short single-driver fling with the W4-616.
#9 |
I have a feeling that the w4-616s may be equal to or better than the 4" radio shack.
#10 |
The 616 has no highs, the -10 dB @ 15 Hz in the manufacturer's curve is for real. Nice midrange though. The bamboos have a touch of roughness caused by a peak around 8 kHz as I recall. A better overall choice full range to my ears.
| Filter for 4" FR Tang Bands | revans | Parts | 1 | 28th February 2009 12:56 PM |
| More Zaph's Tang Bands | cj.9 | Multi-Way | 0 | 1st January 2006 08:56 PM |
| EBS Aligned Tang Bands? | sharpi31 | Full Range | 4 | 27th November 2005 11:16 PM |
| Zaph's Tang Bands ? | cj.9 | Multi-Way | 5 | 21st June 2005 11:52 PM |
| Resistance box for Tang Bands | Eccu | Multi-Way | 1 | 25th November 2004 07:33 PM |
| Page generated in 0.11742 seconds (76.90% PHP - 23.10% MySQL) with 10 queries |
