Old 24th August 2006, 02:22 AM   #1
audiophile36's Avatar
Default DIY Super Cube full range speakers
Since my room is so small I need small speakers,the OB's i made with the same 4" driver were nice but I wanted more bass so I built these babies! These cubes are strong down to 50hz with useable bass at 40hz according to my frequency test LP.To get bass reinforcement anywhere I place them I decided to place the port on the bottom of the cab.My stands have rubber isopads to allow the port to breath.The port is loaded with a 3" long pvc pipe.[IMG]Click the image to open in full size.[/IMG]
If it sounds good it is good!
Old 24th August 2006, 02:25 AM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default er ..ok..
further details?
stew -"A sane man in an insane world appears insane."
Old 24th August 2006, 03:15 AM   #3
Default back of speaker
Old 24th August 2006, 03:17 AM   #4
Default system pic with Super Cubes
Old 24th August 2006, 03:29 AM   #5
type is offline type  United States
They look good. What drivers are you using? Is that your own cabinet design?
Old 24th August 2006, 03:44 AM   #6
Thanks for the complement.The drivers are unknown... I retrieved them from an old pair of speakers my father gave me.They have treated foam surrounds and a whizzer cone.On the back of the magnet it reads "9300/9900 4ohm".Yes, the enclosure is my own design.
Old 24th August 2006, 04:00 AM   #7
The cabinets are 8" square and have a 1-3/4" diameter port on the bottom center of the box which is loaded with a 3" long pvc pipe running up the center of the cabinet.I use a nice amount of fiberglass insulation on all sides and around the port tube just so the opening of the mouth is visible. I used Boiled Linseed oil for a classic hand rubbed oil finish.
Old 24th August 2006, 10:51 AM   #8
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Looks very nice.
For future projects you may want to bear in mind a cube is a not ideal for standing waves, and neither is a square baffle with the driver centred for for baffle diffraction.
You also need a lot more breathing room for the port ideally.
Not trying to put a damper on things, they do look nice - but you could get even better results
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 24th August 2006, 06:42 PM   #9
Thank's makes perfect sense.I will try another project the proper way and post my results.
Old 24th August 2006, 07:05 PM   #10
tade is offline tade  United States
Send a message via AIM to tade
I like your experimentation!
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
Audio Nirvana Full Range Speaker -Super 8 model ttan98 Full Range 33 3rd July 2006 04:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
