Sonic T-amp and RS40-1354 speakers, now which speaker box?
Old 23rd August 2006, 11:58 AM   #1
gychang is offline gychang  United States
Default Sonic T-amp and RS40-1354 speakers, now which speaker box?
I need to build my first DIY project. Is the BIB project the best for what I have?
Can it be done with RadioShack speaker?, anyone have experience/recommendation with the combo?
thanks,
gychang
Old 23rd August 2006, 12:10 PM   #2
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
There are a few design mentioned here:
http://www.diyaudio.com/forums/showt...threadid=83881
All the designs in there should be fine with T-Amp.
Old 23rd August 2006, 12:20 PM   #3
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Depends what you call 'best'.
Terry Cain's original BIB enclosure was for the RS 40-1354, so if you've got at least a rear wall to load it, preferably corners, you'll be in business. It'll shock you, the amount of LF power you can get out of these little drivers.
Alternatively, Bob Brines' straight pipe which you'll find on the link below is also a great box. It depends on which design approach and methodology you prefer.
http://www.geocities.com/rbrines1/Pa...ight_Pipe.html
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 25th August 2006, 01:52 AM   #4
Default need help on straight pipe!!
on the straight pipe design:
A. is the speaker mounted on the slanted or the straight vertical face?
B. is the port on the bottom on the same side as the speaker or on the rear?
C. I know nothing about electronic kit building, if I take the electronic baffle circuit to radioshack, can they put one together for a few $$?
thanks in advance.
gychang
Old 25th August 2006, 02:44 AM   #5
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Default Re: need help on straight pipe!!
I built them with the driver on the vertical side, but since the driver is a little low, a case can be made for putting the driver on the sloped side.
I built them with the ports on the driver side, as I do with all of my speakers. However, there should be no problem with putting the port on the back side as long as the speaker is a foot or two from the wall.
Not a chance. They don't even have the parts you need. RS only interests any more are computers and cell phones.
Bob
Old 25th August 2006, 11:41 AM   #6
Default Re: Re: need help on straight pipe!!
Bob
Bob, thanks for the input, now I have to learn to read the electronic codes??
You mention lining the inside with vinyl using mastic tape, should I go to Home Depot floor dept or parts express and order particular part...
thanks in advance.
gychang
Old 25th August 2006, 11:49 AM   #7
is there a place that sell the electronic baffle circuit alreay made since I know nothing about the electronic circuit building...
gychang
Old 25th August 2006, 09:06 PM   #8
Bob Brines's Avatar
Default Re: Re: Re: need help on straight pipe!!
gychang
Home Depot or a like store will have cheap vinyl floor tile. Mastic is the glue normally used to apply flooring. Alternatively, you could use "Liquid Nails".
In all of my current designs, I use 1/4" cement backer board and "Liquid Nails", but you would have to resize the "Straight Pipes" to use this thicker product.
Bob
Old 26th August 2006, 12:57 AM   #9
Default Re: Re: Re: Re: need help on straight pipe!!
Bob
I will add 1/2" to the inside dimensions and use the cement backer board and liquid nails.
I appreciate your expert opinion very much, thank you.
gychang
Old 26th August 2006, 06:23 AM   #10
3-LockBox is offline 3-LockBox  United States
Default Re: Sonic T-amp and RS40-1354 speakers, now which speaker box?
thanks,
gychang
I can't believe I almost missed this. I'm prolly not the best one to answer this, because I got a Super T, and not a regular SI T-amp. However, I am using 40-1354s with the T and I'd say that you'll be very happy. Here' s a link to my project.
http://www.diyaudio.com/forums/showt...threadid=84078
But if you got the room and the money, may as well go for the BIB
(insert clever anecdote here)
Sonic T-amp and RS40-1354 speakers, now which speaker box?Hide this!Advertise here!
Radio Shack 40-1354 speakers mltaunt Multi-Way 20 19th February 2014 12:46 AM
metronome from RS40-1354? gychang Full Range 6 8th January 2007 01:56 PM
Sonic Impact 5066 with $100 speakers joecool Class D 7 20th May 2005 09:34 PM
Will a Sonic Impact Drive 2ohm speakers? Tuber Class D 1 22nd March 2005 06:32 PM
RS40-1044 8" Fullrange TQWT Design? hearing aid Full Range 3 13th April 2002 03:24 AM
Copyright ©1999-2017 diyAudio
