Old 4th May 2009, 05:13 PM   #1601
chrisb is online now chrisb  Canada
Originally posted by archrival
.... snip:
What am I missing?????
analogies have limitations - or rather, each of us "understands" them to a greater or lesser degree, based on our own experience
one of my greatest audio revelations in over 40yrs is something I still don't understand fully (indeed, who does?) - EnABL
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 4th May 2009, 11:27 PM   #1602
Have still been wrestling with this, will probably end up setting the router up and adding some test curves to these. Based on some of the dimensions given for curvy chang will probably try two, one at the 15" depth originally given by ron, second at 7 1/4". (Or ?????)
Will have to clear some space on the bench for a pivot this long!
Would still appreciate some feedback with respect to the "combining" aspect of the curve. Or on a similar train of thought, why does this work better than two curved mouths (think A126) at the top and bottom of the saburo?
Enjoying the journey.
Old 5th May 2009, 08:14 AM   #1603
Scottmoose's Avatar
The focusing is a difference rather than an increase in performance per se.
I junked the idea long ago for this cab. To gain the necessary baffle-support, you have to make the side extensions either side of the driver extremely deep -so deep that you get a cavity resonance (standing waves) between them, which is the last thing you want rippling through the midband. Bad idea.
Old 6th May 2009, 04:04 AM   #1604
Thanks for the heads up! Will scrap the large curves, would there be any advantage to curving both of the mouths (like A126)?
Old 6th May 2009, 07:18 AM   #1605
Scottmoose's Avatar
It'd theoretically improve the aspect ratio somewhat, but given the configuration, you'd be unlikely to hear any differences. I'd leave it alone.
Old 6th May 2009, 02:03 PM   #1606
Fair enough, boxes stay as is.
Old 7th May 2009, 12:36 AM   #1607
mightym is offline mightym  United States
mightym's Avatar
Location: Checotah, Okrahoma former home of the Okra Fest
Default Shadow Sub...
Gents,
Could the Tang Band sub ref. here: http://www.parts-express.com/pe/show...number=264-832
be considered a substitute for the recomended driver?
could it be used with a change of the vent size/length?
It's about 1/2 the cost of the CSS SDX7, and by accounts I've seen has quite acceptable performance.
Just curious.
John
Old 11th May 2009, 08:34 PM   #1608
Default Mark Audio Alpair 10 BVR
I built a pair of the Jaguar Alpair enclosures of baltic birch, and they are not working as I would expect them to. Previously, I built a pair of mlqwtl of double mdf and they work extremely well. Adding the second layer of mdf made a noticable improvement
The BVR's have substantial high frequency output in the mid range from the vents. Sounds like harmonics in the soprano vocals. I added some poly stuffing, which tamed it a bit, but now it sounds congested.
I'm driving these with a pair of pp kt88 amplifiers. The speakers are a few feet from the side walls and ten feet from my listening position.
Any input appreciated.
thanks
Les
Old 12th May 2009, 07:47 PM   #1609
I believe I found the problem: resonance in the walls of the chamber. I used a brace, vertically from front to back. the side walls, even of 3/4 baltic birch were ringing like bells.
As an experiment, I clamped 3/4" plywood boards diagonally to the sides. the problem went away even with the stuffing completely removed.
Old 22nd May 2009, 12:13 AM   #1610
Been condering about a half-Jaguar (WAF issues)...something like the Brynn - remove the top vent & horn
Any major flaws with this?
Page generated in 0.12449 seconds (77.67% PHP - 22.33% MySQL) with 11 queries
