Spawn of Frugel-Horn
Old 20th September 2006, 11:43 AM   #121
earsandeyes is offline earsandeyes  Netherlands
earsandeyes's Avatar
Looks smart
What would be the overall dimensions?
regards
earandeyes
Old 20th September 2006, 11:44 AM   #122
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Sorry, a very little change
Old 20th September 2006, 12:03 PM   #123
Thanks, well lets see....you need driver positioned at listening height about 90cm....if you double that you have total height of 180cm
I guess it will need to be about 50cm wide....and depth between 15-30cm....depends on driver
But actually I like this odd "fellow" fore its simplicity, triangular CC and only two 90 degree bends....and LONG transmission of mouth....but can be a little less wide than shown...maybe 80cm.....and with "frugel-cutout" it could look very sculptural, but may sound better without
But every horn needs to be drawn in full scale to know exactly
Old 20th September 2006, 08:24 PM   #124
GM, you asked for a corner-basshorn, and could not help trying and you are right, I may have seen something similar somewhere, cant remember
Its only a rough drawing of principle - but I would like you to comment on which driver placement is best, version 1 or version 2, thought about that some time ago
Driver I would think be a 10" ?
Old 20th September 2006, 09:08 PM   #125
Got this crazy idea - frontmounted small 4" in its own chamber, could be made with fronthorn/waveguide
and inside mounted, two small bass woofers
I guess fullrange and woofers must be driven with seperate amps
Old 20th September 2006, 11:51 PM   #126
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Hear the real thing!
Old 21st September 2006, 12:02 AM   #127
qi is offline qi
WAY COOL!
Is it an owl?
Is it a moustache?
Is it an alien?
Who does it sound?
Who cares???
This is ART...
Old 21st September 2006, 12:42 AM   #128
soongsc's Avatar
Designed to stimulate the imagination. Some people called the single driver version the "sperm".
The low end below 100Hz did not come out as sooth as the single driver version, I think it probably has something to do with the drivers in parallel. But the high is extended to at least 40KHz by the super tweeter starting at 10KHz revealing more detail and more "air".
I just put this here for fun because the side firing horns posted previously had a similar concept.
Old 21st September 2006, 03:54 AM   #129
Geek is offline Geek
Geek's Avatar
I agree, that's a piece of art Soong I'd love to see something like that done.
Old 21st September 2006, 04:24 AM   #130
soongsc's Avatar
Thanks,
I call the single driver one (the avatar) Lullaby. It's already up and running.
The MTM one I call Serenade. I only have one test enclosure running at the moment to test the concept.
I'll post a different thread when two channels are up.
Spawn of Frugel-HornHide this!Advertise here!
