fullrange/midbass driver I can run without crossover?
Old 11th August 2006, 09:41 PM   #1
Greggo is offline Greggo  United States
Default fullrange/midbass driver I can run without crossover?
I have a small Fostex full range (FE88ES-R) I am going to run on the front baffle of a small floor stander design I have in mind (inspired by Omega Super 3 XRS), and would like to run another 8 ohm speaker on the rear baffle that will help add some ambience and some bass at the same time. I don't need deep bass as I will be using a small sub, but I do want to skip using any circuits in the signal path between amp and speaker. Since my Fostex cover 120hz and up quite nicely, and my sub will handle everything below 80hz, I am looking for a midbass or full range driver that is:
1) Inexpensive (less than $100/pair US would be great, would pay a little more if the stars line up...)
2) Has reasonably strong output in the 70-100z region (not too worried about ragged response in the upper mids to highs as I will use mechanical solution, as in a gutter filled with stuffing that faces the driver blocking and absorbing most high freq output as it should be beaming, but spaced out a few inches so the bass and mid-bass is free to escape and wrap around the cabinet to support the front firing driver)
3) not greater than 10 inch flange or 4.5 inches in mounting depth
NOTE: and I guess I should point out that my receiver will set a high pass filter at 80hz so anything below that will be on a second order slope and blending into the subwoofer.. so these aren't goint to be true full range, crossover-less designs, but close : )
Any ideas? I am really scratching my head on this one as I have more faith in subjective experience from others on this one rather than looking at response charts as you never know what kind of character a driver is going to have if left to run full range on its own.
Thanks for any and all ideas, (including criticisms/ideas on my speaker system concept in general...)
Greggo
Asheville, NC
fullrange/midbass driver I can run without crossover?Hide this!Advertise here!
TDL RTL-2 - midbass driver search Audiomaniac2 Multi-Way 11 25th November 2013 01:56 PM
Driver for Midbass Thump? done OB style Antripodean Multi-Way 14 22nd July 2009 12:55 AM
midbass driver for BLH e-side Multi-Way 0 18th February 2006 04:41 PM
best 8" midbass driver kegger Multi-Way 10 13th May 2004 03:55 PM
looking for dynaudio 15W75 midbass driver cowanrg Multi-Way 7 6th May 2004 07:40 PM
Copyright ©1999-2017 diyAudio
