Hi, Does anybody know these speakers?
I'm looking at a peak 8CX- 50 but i suspect it is a Coral. (same model# and specs). Does anyone know anything about them? Thanks Colin |
#2 |
Coral OEM'd for a lot of other speaker brands, so it most probably is Coral if it looks exactly the same...
94db/1m/1W (100dB at shorter distance ~1/2m) 2uF cap for tweeter. Replace it with new polyprop if you can. Highish Q. http://www.h3.dion.ne.jp/~roktal/unit/8cx50.html |
#3 |
Thanks Fred, appreciate the info.
#4 |
#5 | |
I too have a pair of the Peak 8CX50's and I'm building them a pair of Coral 8CX501 BR cabinets. Do you mind if I ask what you've done with yours? Doug PS I quickly knocked together a pair of OB's for them. Fantastic!
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all." |
#6 |
Cool. I have a half dozen 10CX501 and have been wondering what to do with them.
#7 | |
Sell me a pair? Doug
#8 |
I had 4 of the 501s, two per back loaded horn enclosure - about 17 -18 inches footprint and 31 inches tall, Mouth was 10 X 17 inches.
Since these added to about 16 ohms imp. and I had two goodmans horn 15 ohm trebax horns I used the goodmans crossovers. I had some old dome tweeters which I put in series , one vertical and one facing forward. They sounded so immediate and impressive - effortless. The tweeters on top sounded better than the horn tweeters on the 501s, possibly due to lobing issues with speakers being side by side. The opening tracks of Dark side of the moon at any volume was scary. As were the alarm clocks!!! Not very scientific a setup but I want them back!!!!!! These were the speakers I mentioned in an old thread to do with listening experiences. They were run off a Lynsley Hood 75 watt SS amp. jamikl |
#9 |
Does anyone have the T-S parameters for these?.
GM posted a set (with a qualification) but I have not been able to reconcile my measurements with his. Thanks |
#10 |
Here's a pic of my 8CX50's:
| FS: Coral alnico 6 inchers and Coral H-12c alnico tweeters | MichaelPublic | Swap Meet | 2 | 27th June 2008 11:24 PM |
| 200V peak to peak @25MHz | ketan | Parts | 1 | 8th June 2008 03:21 AM |
| 116 db peak db how loud is that | 8cube | Multi-Way | 21 | 8th November 2007 06:45 AM |
| Pre Outs and peak-to-peak ? | CheekyMonkeyVZi | Car Audio | 7 | 12th December 2006 08:30 AM |
| a peak at a TDA7293 amp | quekky | Chip Amps | 17 | 8th February 2004 11:37 PM |
| Page generated in 0.11378 seconds (80.36% PHP - 19.64% MySQL) with 11 queries |
