Try Diyparadise, Yeo is still showing some Coral drivers for sale.
He may have some info on other Coral units.
http://diyparadise.com/coral_enclosures.html
Hi Albert
The best You can get with the flat 10", an amasing driver, is the Schmacks horn, use the plans for 8" driver and move the first wall of the "cone" one inch so You open the "throat area" about 5mm per side. I have modified the Schmacks design for Beta/flat 10"
units, a lot more complicated to build but if You want drawings let me now.
Ingvar
Ingvar
The Flat 10 is similar in specs to the Beta 10 so you can use the Coral designed BLH for the Beta 10 or you could also put it in the Coral designed BR box for the Beta10 like what we did.
The highs were a bit weak so we added the ESS AMT tweeters on top , a very musical combination
4fun said:Beautiful nice drivers, seldom seen today! (At least not by me).
Do anyone have some info to share about Coral's history, it would be interesting....
Here you go...
http://www.eastmarinedrive.com/contents/non-static/coralfr-content.htm
East Marine Drive's website probably has the best Coral documentation around. Btw there's also a interesting Flat 10 cabinet design right down below.
Link to Coral info
http://www.077.dk/coralflatseriesbrochure.html
Hope this will help. I have some Flat 6s for sale on the Trading page as well.
Harry Z
Harry Z
albertli said:BTW,
Can you tell me the size of the pipe?. Please.
Albert
East Marine has the plans for this 5 port BR Coral box, which you can download. The diameter of the pipe is 75mm in diameter. This BR box is simple to build and sounds very good too.
- Full Range
- Coral Flat 10
