Need TL plans - Page 2 - diyAudio
Old 15th July 2006, 03:55 PM   #11
edjosh23's Avatar
Godzilla actually told you it would be 69" tall internal.
Pioneer B20FU20-51FW 8" full range
L = (Line length) 138"
So = Driver 30" down from sealed end of cabinet
Sm = 200"^2
All internal
That means you halve L to get cabinet hight = 69"
Sm is mouth volume or your foot print. I'd suggest using the golden ration 1.618. Then you get out your calculator and plug in numbers to find the other dimensions. 11" x 18" = 198"^2
You can choose those dimensions or come up with your own and more accurate or larger dimension.
Once there you you your internal volume and all internal dimentions. 69" x 11" x 18" .
Last thing to do is to find the length of the internal taper baffle. I'm not going to figure that out, that takes a bit more math, but is not diffucult. My suggestion would be to draw out your plans to scale.
Josh
Old 15th July 2006, 06:11 PM   #12
Send a message via AIM to weikertball Send a message via MSN to weikertball
yeah, I got those dimensions once I worked on it....for a while. The inside baffle shouldn't be too hard to find if it's going to be 10" away from the bottom, front and back of the enclosure. It will be 10" away because it's half of the depth (a=b=c=d/2)
Old 15th July 2006, 10:23 PM   #13
edjosh23's Avatar
The internal baffle will be 10" away from all sides if your Sm is 20"x10"
Josh
Old 15th July 2006, 11:00 PM   #14
GM is offline GM  United States
GM's Avatar
Greets!
http://www.diyaudio.com/forums/showt...572#post942572
http://www.diyaudio.com/forums/showt...832#post943832
http://www.diyaudio.com/forums/showt...770#post945770
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th July 2006, 03:59 AM   #15
welp, I have some building to do
Has anyone got any plans for a car amp? GW Chip Amps 1 27th May 2004 01:41 PM
Has anyone got any plans for a car amp? GW Tubes / Valves 4 27th May 2004 05:27 AM
Help with Sub Plans mitch808 Subwoofers 10 1st May 2004 12:00 AM
VTA plans someone? Zen Mod Analogue Source 7 31st January 2003 01:56 AM
Plans and changes Andy G Multi-Way 4 30th September 2002 02:30 PM
Copyright ©1999-2017 diyAudio
