This is a joke, right?Jaime said:I have an old 12” Philips woofer but I do not know the designation.
I believe that it was made between 1970 and 1975. It has rubber surrounding.
Which is the designation?
Which is the Thiell and Small parameters?
Best regards Jaime
I can't see where the insertion of humor would be
T/S params can easily be obtained on an unknown driver with equipment I'm sure >50% of us have:
http://www.mhsoft.nl/messen_en.asp
And the numbers stamped on the frame are traceable online with popular manufacturers, like Philips.
or a 1256w4/8
these are certainly an above average speaker
similar stuff-
http://www.mfbfreaks.nl/folders/1974/1/imagepages/image23.html
similar stuff-
Jaime,
I´m from Montevideo, too, and I have some long, long affaire with philips drivers, so it is possible that digging deep in my library I could find some specs of that driver of yours. Usually, philips woofers were designed to be used in acoustic suspension alignments, giving optimal volume as one of the few parameters in their catalogs, but fullrange ones as the 9710M and for instance AD12100M were best suited for alignments such as bass-reflex or horns, where no high x-max were needed or wanted.
Mar
Mar
- Full Range
- Old 12” Philips woofer
