How best to use FE127?
Old 30th June 2006, 12:55 PM   #1
Spasticteapot is offline Spasticteapot  United States
Send a message via AIM to Spasticteapot
Default How best to use FE127?
I'm thinking about using a FE127 in combination with a T-amp or Gainclone for my new stereo system. They're certianly cheap enough, at about 35$ each at Madisound, but how should I use them?
MLTL's are supposed to work well, and the ABS pipe design at T-linespeakers.org (under http://t-linespeakers.org/projects/sampson/fe127tl.html) is very appealing. I'd like to try using an active baffle-step filter before the amplifier, though, to save money and improve sound quality.
Also, I was thinking about using a tweeter, too, if I can get access to a suitable tweeter. Is this unecessary?
Also, would you reccomend that I instead go for the TB "bamboo" driver, or another similarly-price FR option?
Old 30th June 2006, 03:02 PM   #2
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
Planet10 (Dave) has a design for the 127 thats aperiodic. I got to hear it with modded 127's a few weeks back and they sound real nice. I'd get in touch with him, he also sell's the modded version of the 127 driver which is much better than stock. Dave
Old 30th June 2006, 05:56 PM   #3
x. onasis is offline x. onasis
After hearing the differences between this and other similar drivers used in mono and bi-pole projects, I would highly recommend going bi-pole from the start.
I'll be very interested in hearing Dave's input, as he's played with many more designs. But for this kind of outlay, if you have the room, you'll be building a much more dynamic and engaging speaker.
onasis
Old 30th June 2006, 07:05 PM   #4
loninappleton is offline loninappleton  United States
You should look at the FE127 reference project if you
have not seen that-- it has not been added to in a while
--and will show how a build it designed from the ground
up.
I went with the MLTL design from GM with dims
that are posted on the godzilla site. I did a bit of
customization on the port but I'm still using my
scratch build made from some fiberboard shelving
which just happens to be the right size for minimal
cutting to the right dimension.
Old 30th June 2006, 07:30 PM   #5
chrisb is offline chrisb
I'm not Dave (just the the hack who builds all his design prototypes), but let me say that for a mono-pole the folded MLTL makes for a nifty little package, but to my ears is bested by the "Fonken".
Given appropriate floor space, the straight bipole MLTL adds an extra dimension to the soundstage over either mono-pole design, as well as increased sensitivity, and mitigates the need for BSC.
Old 30th June 2006, 07:30 PM   #6
edjosh23 is offline edjosh23  United States
edjosh23's Avatar
I build a pair of GMs MLTLs, but I think that I may build Dave's Fonkens.
Dave's Designs
Josh
Old 30th June 2006, 08:14 PM   #7
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
The Fonkens are the way to go IMHO. After listening to them and some of the other 127 based speakers, I decided this was the way to go. My version has slightly different port dimensions compared to Dave's. I used the xls Onken spreadsheet while staying with the 13L volume.
Jeff
Old 30th June 2006, 08:17 PM   #8
Jeff
The Fonken looks great. I may have to make someone else make it for me, though. (Much bribes will be in order.)
Old 6th July 2006, 01:23 AM   #9
bluegti is offline bluegti  United States
Default I'm listening to the reference project right now...
I built these because this was my second pair I ever built and it seemed pretty easy to build. I'm using them with a pair of Bottlehead Paramours in a pretty small room - 12 x 12.
At first things were a little on the bright side - to be honest I was disappointed compared to some JMR Twins that I was using before. They have about 100 hours on them now and they are definitely smoothing out and the bass is starting to fill in. Now, I'm pretty happy. I think I've read they have a fairly long break in, so I'm expecting them to get even better.
How best to use FE127?Hide this!Advertise here!
FS: NIB FOSTEX 4 X FE127 $39 each dhenryp Swap Meet 1 8th February 2012 02:52 AM
Fe127 E oceancity Full Range 4 23rd April 2009 06:13 AM
FE127 in MLTL davidallancole Full Range 35 29th April 2008 03:10 PM
FE127 for in-wall speaker? Xor Full Range 8 30th May 2007 03:25 PM
FE127 project edjosh23 Full Range 43 25th September 2005 11:33 PM
Copyright ©1999-2017 diyAudio
