#11 |
Wilmslow Audio are now dealers for Fostex and should stock most of the drivers and other bits and pieces. They also do flat pack cabinets for some of the Fostex designs. FWIW, I agree that the Cain designs are some of the nicest-looking out there.
A point not mentioned so far - are you okay with using the speakers away from the walls or would you prefer something which backs to the wall or corners? That might help decide the bass loading and extension. |
#12 |
Don't know about the table,.....
I wish I could find that table. Someone had calculated maximum SPLs for the whole range of Fostex drivers (accounting for two speakers, room effects etc.). In fact I saw it posted in two seperate messages - somewhere... Steve
Stephen Almond |
#13 | |
Colin, Yes, I remember Wilmslow Audio from when they were in Wilmslow! The speakers may be near side walls (room is about 18ft x 11ft) but they will NOT be near backwalls. My sofa is against one of the short walls and the speakers will be placed a suitable distace towards the far short wall, but not anywhere near 18ft. Maybe about 12ft down the room from the wall behind the sofa? I assume this means horn type speakers won't get the location they prefer? Steve
Stephen Almond |
#14 | ||
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#15 | |
frugal-phile(tm)
You could also consider something like the Bi-Fonken or the simplier to build bipolar diyAudio ref ML-TL. Being bipoles, baffle-step compansation is built-in (note here that i think that 4-5" is the sweet spot for the Fostex drivers), I am listening to FE167s right now thou and they aren't far behind (i'm working on a Fat Fonken for these as well as figuring what cone mods work) dave
#16 |
I'm sure there are some good ones. I've only personally seen two at a 'reasonable' price with what I would classify as decent output transformers though -Shanling monoblocks with EL34s. But the component quality wasn't great in those; could be usefully upgraded. I imagine some of the higher priced Consonance products are good too. The cheap ones I've had to play with reminded me of inferior varitations of the Quad II -they just can't swing full output into LF before saturation.
#17 | |
frugal-phile(tm)
"a tweakin' we shall go, a tweakin' we shall go, hi ho the ..." dave
| Confused about DVC and Q | mashaffer | Multi-Way | 13 | 30th July 2006 03:40 PM |
| Help Confused | jwatts | Subwoofers | 2 | 26th June 2006 11:12 AM |
| i'm confused ... | sss | Multi-Way | 5 | 11th May 2006 12:03 AM |
| I'm Confused and I need your help. | Paprika | Solid State | 12 | 22nd September 2003 07:49 AM |
| Page generated in 0.10947 seconds (75.41% PHP - 24.59% MySQL) with 10 queries |
