Jordan JXR6 Group Delay
Has anyone seen a group delay/phase plot for the JXR6?
The on axis response looks workable, potentially excellent, and the impedance plot looks virtually flawless. Besides the need to cross over in the lower midrange, whats up with this driver? too good to be true? |
Re: Jordan JXR6 Group Delay
Could you post some pics of your measurements? I've worked with JX53 and the early JXr6, they all are exellent. Very good detail due to the extended FR and phase characteristic. You are looking at a product that a man had spent over 40 years of continued improvement. |
I'm not an owner, I'm a potential owner.
I'm an owner of a pair and they sound excellent, with no additional need for a tweeter. I have a pair running in 2 litre sealed enclosures and they work very well in smaller rooms without further bass (they start to roll off at 120Hz so putting them against walls or into corners helps lift the LF).
They're not super efficient, about 89dB/watt, but work fine with a Sonic T-amp. The JXR6 has a line of development which goes back to the mid-70s, when Ted first started working on a 2 inch, wide bandwidth driver. |
Wouldn't tell you much, why you don't see them that often. Massively affected by the baffle and the low frequency c/o. Limitations are likely dispersion at the top end and running out of excursion at the bottom end if you c/o too low. Real efficiency is 86dB/W, adding baffle step for a small box would bring it down to ~ 83dB/2.83V (80dB per 4ohm watt). :)/sreten. |
I would avoid doing a BSC with the JXr6 unless you are prepared to invest more money into the circuit than the driver itself. Most component quality would degrade the performance. If I did another design with it, I would find a good bass with greater efficiency and cross where the BSC is supposed to come in. If you can find some old JX53 charts, the off-axis response would probably be similar. I haven't sampled the latest versions yet, so I'm not sure how the bass is going to be, if it's possible to make a BLH design work, then you probably have a winner. |
Thanks for the recommendation Colin.
down to 100Hz ? I don't quite understand what you are planning. take a look at this : http://www.t-linespeakers.org/projects/rune/index.html :)sreten. |
Old JX53 web page is here
I think the cone design is the same as the JX53 but everything else is new, including the suspension, which may allow it to go higher as well as lower. I presume the 86dB efficiency is because this is really a 4ohm driver? I'm not sure how Ted is measuring efficiency (ie whether he takes that into account). It goes slightly louder for a given input than my JX92 (not by a huge amount but it is noticable when you try and match them up) which in turn was similar to a ScanSpeak TL system I had which was 8 ohms, rated at 89dB. I've been pleasantly surprised that the JXR6 sounds ok with the 6 watt sonic t-amp (but then in the week I've had it I'm still surprised at most things this ridiculous little noddy amp achieves). |
| All times are GMT. The time now is 07:30 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
