Jordan JXR6 Group Delay - Page 2 - diyAudio
Old 23rd June 2006, 12:31 AM   #11
Dumbass is offline Dumbass  British Antarctic Territory
IMO using SET would be underpowering the driver, unless for only low-level listening, in which case why spend so much money.
Old 23rd June 2006, 01:05 AM   #12
lndm is offline lndm  Australia
Hmmm, I could (and have considered) rolling off the signal to the SET in the lower midrange giving me headroom, and <gasp> build a SS amp for the bass.
Old 23rd June 2006, 08:52 AM   #13
Colin is offline Colin  United Kingdom
Rolling off around 200-250Hz would probably be ok and let you get away with a lower powered amp (though 2-3 watts may be too low). BTW, by straight baffle, do you mean an open baffle? The JXR6 requires a sealed enclosure for its suspension to work properly.
Old 23rd June 2006, 09:48 AM   #14
I have about 10W to play with.
No, just speaking for the front baffle, I always treat the cabinet face independently of the enclosed volume.
Besides this, I'm thinking that if I use an active filter I could put the JXR6 into the larger 4L enclosure.
Old 26th June 2006, 09:23 AM   #15
This may be a little off topic...
But...
I'd really like to see zaph's take on this driver...(www.zaphaudio.com)
Anyone have a spare they'd like to mail his way for the small driver tests? I can see where one might be hesitant to send away their uber expensive mini drivers when there is the small chance a 10 dollar hi vi might outperform it
Old 26th June 2006, 09:39 AM   #16
soongsc is offline soongsc  Taiwan
soongsc's Avatar
But...
I doubt that hi vi can out perform is in terms of fidelity. Since the JXr6 has a smaller cone, the low end is somewhat limited in comparison with 3" drivers. But other than that, very hard to beat.
Hear the real thing!
Old 14th September 2007, 01:50 AM   #17
jnb is offline jnb  Australia
my JX92 <snip>I've been pleasantly surprised that the JXR6
I'm thinking of combining one of these with a woofer. Which of them in your opinion has the better midrange and treble?
Old 14th September 2007, 08:54 AM   #18
The JXR6 definitely has the better midrange and treble. It is more refined and goes higher.
BTW, ref some of the comments about baffle step. I've found an effective (although not cheap) way is to combine two units in each enclosure.
The availability of suitable woofers will be improved once EAD put the JX125 and 150 back into production.
Old 17th September 2007, 07:31 AM   #19
lydan01 is offline lydan01  Australia
lydan01's Avatar
I have the JXR6 within some 2ltr enclosures driven by the Trends Audio little T-Amp... Sounds great, but definitely needs some help on the bottom end.
My plan was to add the following Sub-kit to the mix - it can crossover up to 200hz which I was thinking would add some much needed weight to the sound.
http://www.d-s-t.com.au/data/hds-xls/ins800.pdf
Jordan JXR6 HD Designs PrimaLuna Full Range 89 20th December 2013 10:25 PM
Jordan JXR6 HD vs JX92S oceanic30 Multi-Way 1 25th August 2007 08:54 PM
Using in the Jordan JXR6 HD in an MTM David Gatti Multi-Way 3 7th November 2006 07:52 PM
Jordan JXR6 driver array neil_kaye Full Range 1 21st September 2006 08:54 AM
Partner for the Jordan JXR6 jimbo Full Range 23 13th March 2006 11:41 AM
Copyright 1999-2017 diyAudio
