Jordan with a Ribbon MLTL
Old 18th February 2013, 05:58 PM   #211
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Originally Posted by northernsky View Post
in case of combination with a tweeter such as Griffin minimonitors, EAD suggests the cheaper E100 since the improvement of the E100HD should only be on the HF
northernsky
thanks again! I had a quick look at the 130and 170 drivers and thought 'eugh!' so perhaps youre correct!
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 5th March 2016, 10:49 PM   #212
Industrialsized is offline Industrialsized  United States
first sorry for resurrecting a very old thread but has anyone biamped the mini-monitors and what crossover setting would you use i know say 3000 but what slope and what about sub crossover around 70 and again what slope?
thanks for the time, Dustn
Old 6th March 2016, 05:03 AM   #213
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Default https://www.madisoundspeakerstore.com/ribbon-tweeters/fountek-neocd3.0m-blk-3-ribbon-
I built these speakers several years ago but based on later experience I would suggest this tweeter - all agreed it sounded more natural.
I would suggest 18db / octave but what ever rolloff you use with ribbons you ABSOLUTELY MUST HAVE A FILM CAP IN SERIES WITH THE TWEETER - otherwise you are presenting the amps with a full short circuit.
mike
Old 6th March 2016, 01:07 PM   #214
Jim Griffin is offline Jim Griffin  United States
I suggest that you use the mini-monitors 'as is' with their internal crossovers intact. An active crossover can be used between the subwoofer and with the mini-monitors treated as satellite speakers.
I have used this method in my own system. My subwoofer has a plate amplifier and accept line L and R line level inputs from a preamp. The plate amp has an internal crossover which splits the signal between the subwoofer and line level outputs to the power amp for the satellite speakers. The subwoofer crossover has adjustments for the crossover frequency and gain for the sub. The preamp controls the overall volume level once you balance the subwoofer volume to your in-room sound level between it and the satellites.
You can implement a similar configuration with an active crossover processor. You would use separate amps for the bi-amp pair (subwoofers and satellites). The preamp would control the overall volume level while the processor would give you the ability to adjust the in-room balance between the subs and satellites. Some processors offer flexibility to alter time delay between speakers and in-room EQ for the system.
As pointed out by mikelm, if you choose to not use the mini-monitor crossovers, you must take precautions to protect the ribbon tweeters and your amplifiers. Only if you have a crossover processor and amplifiers that self mute on power up and power down cycles can you assure adequate protection. Addition of large value series capacitors are recommended for protection of the tweeters and your amps.
The passive crossovers in the mini-monitors not only perform the crossover function of the mini-monitor, they act to implement baffle step compensation and gain balance between the woofer and tweeter.
Old 6th March 2016, 02:03 PM   #215
thanks for the reply's guys! Jim do you have any thoughts on the fountek ribbons? I tend to stick with known good but if a few people tell me they are better than the g2si I could be swayed.
Old 6th March 2016, 07:08 PM   #216
While Fountek has a good line of ribbons, the Aurum Cantus models are what I have used for several designs over some 12 years now. The G2Si is still available so I would not use a substitute ribbon.
Old 8th June 2016, 10:56 AM   #217
Eirik Uthaug is offline Eirik Uthaug  Norway
I have a pair of Aurum Cantus G2si I want to pair with Visaton B200 in my Open baffle set-up. I got the Jordan/G2si crossover put together, but the Visaton has same sensitivity and impedance as G2si so I would like to modify. I think it should be possible to remove some of the resistances that is put into the crossover originally. When testing this, it plays to low compared with the Eminence 15A used for the low frequencies. This is a OB construction and I am adding the G2si for fun. I am also using minidsp to separate the bass from the high part, but since I have only four channels, I need to add passive crossiver for this.
Would really appreciate if someone could guide me to convert the Jordan/G2si crossover to fit Visaton B200/G2si
Old 8th June 2016, 04:02 PM   #218
Colin is offline Colin  United Kingdom
Ideally you shouldn't treat a two-way crossover as something which can be split and each section changed independently of the other. They're designed as a system. Your driver configuration may need an entirely different crossover to the one Jim arrived at for the JX92S/G2si combination.
See post #214
EJ Jordan Designs
www.ejjordan.co.uk
Old 9th June 2016, 07:44 AM   #219
Thanks for the quick reply Colin! I agree with you that the best way is to develop entire new crossover. My goal is however, to see if there are changes to the JX92S/G2si combination I already have assembled from past project that I could use. The split could be in the same frequency range, but I am afraid I am not utilizing the Visaton B200 enough.
Another question: What is the best (simple use) free software avilable for crossover design and simulation?
Old 9th June 2016, 11:55 AM   #220
This is a very simple online crossover calculator
2-Way Crossover Designer / Calculator
and this gives more details of the processes involved
Passive Crossover Network Design
EJ Jordan Designs
www.ejjordan.co.uk
Jordan with a Ribbon MLTLHide this!Advertise here!
Jordan VTL / GM MLTL-31 hybrid wallis61 Full Range 8 6th January 2009 03:11 AM
jordan mltl 48 Smokeyone Full Range 161 10th December 2008 03:50 PM
Jordan MLTL Enclosure Sealing LizardBrain Full Range 10 24th March 2006 09:50 PM
Sub for a Jordan MLTL - Vifa MA26WR09? cheesehead Subwoofers 5 26th October 2004 02:08 AM
