Old 4th January 2011, 12:06 AM   #191
Toaster is offline Toaster  United Kingdom
Apart from import duty and higher shipping costs I haven't found that buying from North America is an issue, and actual driver costs are often somewhat lower. Although the l-pad resistor values would be different from the AC GSsi, the CSS RT1 (aka AC APR series) should be a drop in for this design and may sound even better Creative Sound - Product Details Good luck with your build!
Old 4th January 2011, 12:39 AM   #192
frugal-phile(tm)
planet10's Avatar
I too was going to suggest that one. I prefer it to the AC IIsi i've had before.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th January 2011, 08:19 AM   #193
Thank you for your suggestion about CSS tweeters, it seems there are also distributors in Europe.
I have only one question since I am not an expert and I can just copy (at most):
do I need to modify the crossover of the original project?
Renato
Old 4th January 2011, 08:49 AM   #194
frugal-phile(tm)
planet10's Avatar
The attenuation of the tweeter will need to be reduced (if not just eliminated). One of the goals of the RT1 was to reduce the sensitivity so as to allow reduction of attenuation required to mate with the CSS midbasses/fullranges.
dave
Old 4th January 2011, 10:06 PM   #195
Is the l-pad attenuator the resistor in parallel with the driver?
I expect that this is a trivial question but if I built this speaker it will be the first crossover of my life
Renato
Old 6th January 2011, 06:35 PM   #196
Parts Express has a nice discoutnat the moment for the G2si tweeter (69$ instead of 92.45$). I think I'll take the risk of the purchase outside European Union (at least for me it is never clear what the custom duties will be)
Renato
Old 3rd February 2011, 10:55 AM   #197
Shiva5 is offline Shiva5  United States
I have some Infinity EMIT-k's and their 4th order crossover (at 4000hz) that I could use with my JX92's in the new 35" cabs. Does anybody know anything about thme as far as matching well with the Jordans?
Jordan VTL / GM MLTL-31 hybrid wallis61 Full Range 8 6th January 2009 03:11 AM
jordan mltl 48 Smokeyone Full Range 161 10th December 2008 03:50 PM
Jordan MLTL Enclosure Sealing LizardBrain Full Range 10 24th March 2006 09:50 PM
Sub for a Jordan MLTL - Vifa MA26WR09? cheesehead Subwoofers 5 26th October 2004 02:08 AM
Page generated in 0.11871 seconds (66.71% PHP - 33.29% MySQL) with 11 queries
