Makizou, I finally did it.
Old 21st August 2012, 06:13 PM   #81
GM is offline GM  United States
GM's Avatar
'Sounds' like the driver's specs are way off, so about all you can do is either get correct enough drivers and/or add however much damping is required to smooth them out with the understanding that they may become little more than a large sealed alignment with a minor amount of extra LF gain BW.
Anyway, for starters, make sure there's no air leaks, then try ~heavily stuffing the filter chamber [driver back box] and report back.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st August 2012, 06:20 PM   #82
James189 is offline James189  United Kingdom
Thanks for the advice, the sides and speaker front panel weren't glued on, just clamped reasonably tightly but I'll get on with attaching that and then see where I'm at.
Makizou, I finally did it.Hide this!Advertise here!
makizou horn alejo Full Range 7 28th March 2007 10:26 PM
finally...I am able to say hello to everybody and everyone. groov Introductions 3 28th August 2006 09:44 PM
Its done finally trailsnail85 Car Audio 0 27th August 2004 06:00 PM
Finally jpb200 Multi-Way 2 26th May 2004 01:58 AM
Copyright ©1999-2017 diyAudio
