Any audio difference between FE166 and FE167 - diyAudio
Old 6th June 2006, 01:12 AM   #1
ttan98 is offline ttan98  Australia
Default Any audio difference between FE166 and FE167
I understand the main difference between 166 and 167 is that the latter is shielded and some differences in Thiele and Small parameters.
Anyone has anyone make comparisons between these 2 drivers in terms of audio quality.
Using T&S parameters these 2 drivers use different box size. Making comparison using the same box size is unfair...
Any comments anyone...
Old 6th June 2006, 01:22 AM   #2
Dumbass is offline Dumbass  British Antarctic Territory
In general, the FE167E would be recommended for simple vented box, while the FE166E would be recommended for rear-loaded horn. You can add series resistance to FE166E to raise Qts, but this robs efficiency.
An interesting compromise would be a Bigger Is Better enclosure:
http://www.zillaspeak.com/bib-fostex.asp
Notice that freq response for two drivers in the same cabinet is very similar. The FE167E has a slightly nicer more gradual roll-off.
FE166E has heavier magnet, one might argue this gives better transient response. If put in rear-loaded horn, this may be a valid point, but we're not talking about a simple box then.
Old 6th January 2009, 02:54 PM   #3
RaphTube's Avatar
Default More feedback please...
Hey, can we get this one going again.
I was just trying to choose between these two for something a TQWT or a TL, or something in between.
-Raphael
-R
Old 6th January 2009, 05:40 PM   #4
hm is offline hm  Europe
hm's Avatar
hello,
take both as bipol double horn
the Posaune
http://www.hm-moreart.de
Old 6th January 2009, 07:51 PM   #5
chrisb is offline chrisb  Canada
Default Re: More feedback please...
-Raphael
a short answer would be that the FE167 is more flexible in terms of types of enclosure in which it can deliver decent to outstanding performance
If you're looking for a simple build that doesn't occupy a lot of floor space, something like an MLTL with the 167 would be a pretty safe bet. (e.g. Bob Brines' famous FT1600, etc)
There are also some enclosure designs that load the driver in a different mode, and entail more elaborate construction, (e.g. Planet10 Fonken167, Scottmoose BVRs- Chili / Kimchi Chang, BIB chamberless BLH, etc )
altogether there are just too many design philosophies and performance expectations to answer the oft asked question "that's nice, but which one is best ?", other than to say - there isn't one
... so, not as easy at it sounds, this letting go thing
Old 7th January 2009, 05:01 AM   #6
Alex from Oz's Avatar
Default Re: Re: More feedback please...
Yeah like the Decware Corner Horns - which suit the FE167E.
I've had the plans for about 12 months but the woodwork is rather intimidating for me!
Alex
Old 7th January 2009, 05:21 AM   #7
Default Re: Re: Re: More feedback please...
Alex
indeed - and to work properly at all they need a dedicated room with corners in just the right places - fine for someone like Steve, but a definite deal breaker for a lot of folks.
Old 7th January 2009, 04:05 PM   #8
LilMik is offline LilMik  Honduras
hello,
imho opinion the 166e has a little bit better resolution and the highs are a bit better.
i would treat the whizzer with c37 laquer or thinned dammar. helps a lot .
both drivers are very good for the price.
cheers,
lilmik
Adding resistance to Fostex fe166 to act like fe167 when needed germpod Full Range 0 26th December 2008 09:20 PM
Fe166 marce Full Range 45 13th August 2007 12:45 PM
I'm anti-expensive audio parts but man, a good capacitor can make a difference jduffy Parts 6 25th April 2007 05:13 AM
Audio v. non-audio ADC chip difference? rif Digital Source 0 18th May 2004 02:40 PM
Copyright 1999-2017 diyAudio
