Pioneer B20 and Visaton BG20 - diyAudio
Old 5th June 2006, 01:06 PM   #1
inrank is offline inrank  United Kingdom
inrank's Avatar
Default Pioneer B20 and Visaton BG20
are either of these cheap fullrangers any good.
thinking of having 2 or 4 in ob with a super tweeter. crazy idea?
cant afford the B200 at the moment, i allready have some CSS Fr125S's in IB which are ok, but looking for a floorstander using fullrangers, and at least 8 inchers as i listen to alot of rock lol
a real ultimate budget speaker
(or do somthing like this.... http://www.zillaspeak.com/pioneerb20-piezo.asp)
Old 5th June 2006, 01:48 PM   #2
inrank's Avatar
or what about this.... http://www.boxen-baustelle.de/de/dept_131.html
very high Qts but only 0.5mm Xmax
Old 6th June 2006, 05:17 AM   #3
Default I asked about the BG20...
Have a look at this thread:
http://fullrangedriver.com/forum/viewtopic.php?id=598
cheers,
Pete McK
Old 7th June 2006, 06:24 PM   #4
edjosh23's Avatar
inrank,
My pioneers are my main speaker. I love them. You can check them out on my website. My box is a bit different fron Godzillas, but I really like these drivers. I have a pair of wr125s, but they have been moved to make space for the B20s. Here is my thread about the pioneers. Infact I just added BSC today when I dropped by a local audio shop.
I have also heard good things about the BG20s and would recomend them as well. The BG20 has lower Fs, high efficency, and greater xmax.
Good luck,
Josh
Old 7th June 2006, 06:32 PM   #5
Godzilla's Avatar
http://www.sounddomain.com/ride/621686/6
Josh those look really great!
I enjoy my B20's at work every day. They are kind of like an innexpensive car that performs very well... and if it can't go 0-60 in 6 seconds flat it's ok because it's still fun. I don't even mind if the boxes get dings in them.
Godzilla
Old 8th June 2006, 10:28 AM   #6
zek is offline zek  Serbia
... and what about Visaton BG20 in BIB enclosure (there is no BIB's for Visaton drivers yet)
Old 8th June 2006, 01:45 PM   #7
I was just looking at the Pioneer FR in box plot and interestingly enough it looks like it might make a nice little sub. Not a lot of Xmax but but can be tuned for nice extended low bass in a reasonably sized box. As an inexpensive option for a bedroom system who knows.
mike
Old 8th June 2006, 01:53 PM   #8
GM is offline GM  United States
GM's Avatar
Greets!
OK, have you made a formal request on the BIB thread?
Anyway, not true, scroll down for the B200: http://www.zillaspeak.com/bib-gm.asp I'm not sure why any BIB designs I've had input on is listed separate.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th June 2006, 02:37 PM   #9
Godzilla's Avatar
Hi GM!
My original intention was to disperse them throughout the thread but it was easier to put them on one page. I will put them in their appropriate places in the coming days.
Pioneer has another 8” driver that looks similar to the B20 without the wizzer cone.
http://www.partsexpress.com/pe/showd...number=290-063
Peace,
Godzilla
Old 8th June 2006, 04:06 PM   #10
GM's Avatar
Greets!
Cool! Thanks for the effort!
FYI, the ~5 yr. old pair I have are strictly midbass units and better suited to small lead guitar practice amps since they begin distorting like right now, so for HI-FI I recommend either sealed or aperiodic with a separate sub system, though if driven with an impedance matching amp, a Vb = Vas, Fb = ~1.62*Fs 'vintage' vented alignment should work.
That said, I mass loaded one with poster tack to both lower Fs/raise Qts and damp down its HF BW (covered the DC and filled in the hollow where it joins the diaphragm) and it shifted the distortion to below my acute hearing BW enough to use it as a LF 'fill' driver for the modest SPL B20 OB prototype I posted about on the original FR forum.
As always, YMMV.
GM
Modify a Visaton BG20 heinz1964 Full Range 0 12th February 2008 09:06 PM
What eclosure for Visaton BG20 zek Multi-Way 7 15th August 2003 05:28 AM
Copyright 1999-2017 diyAudio
