I'm have a project just use driver Fostex fe206e to play mid & high frequency and JBL D140R to play Low frequency (under 300hz). The problem that I don't know how to design the enclosure for driver fe206e to play from 40 to 300hz. Should I use the seal enclosure?
Anybody can help me to design that enclosure? Thanks in advance!!! |
#2 |
You've lost me: which is it? I assume you're wanting to use the FE206E above 300Hz, right? If so, forget enclosures: run it open baffle, and stick the LF driver in either a ported or TL cabinet.
#3 |
Oh, I'm sorry, that my mistake. I intent to use Fe206e to play over around 300hz and JBL under 300hz.
I also intent to used open baffle but I don't how to design that enclosure. Could you show me the design the open baffle for fe206e? Thank you, |
#4 | |
#5 | |
#6 |
Hello,
better cut at 100-150 Hz, at 300 Hz there is to much male and female voice, and you can listen the change between the drivers, of material, acceleration and different SD. 300 Hz is half an oktave below the clay tone a. take better a sat like the TRUMPET or SCHALMEI http://www.hm-moreart.de/1.htm
http://www.hm-moreart.de |
| First FE206E enclosure | beauistheman | Full Range | 4 | 14th December 2008 12:03 PM |
| WTB: GC for Horns 109db 300hz up , some advice please | siepi | Chip Amps | 0 | 12th August 2007 07:23 PM |
| FE206E Recommended Enclosure | Skitch72 | Full Range | 13 | 24th October 2005 05:08 AM |
| FE206E enclosure | tonitze | Full Range | 59 | 6th August 2005 02:41 AM |
| Drivers for dipole sub up to 200-300Hz | swak | Subwoofers | 23 | 15th November 2004 06:57 AM |
