Driver Position - diyAudio
Old 31st May 2006, 09:47 AM   #1
hlj is offline hlj  United Kingdom
Default Driver Position
Hi all
I recently asked this question on another thread, which GM kindly answered (thanks), but suggested i start a new one, so here goes.
I am pretty close to finishing a pair of ml-tqwts, as per attached image. The design dimensions are as Bob Brines folded version of MJK's straight ML-TQWT.
I would like to put place the driver in the position shown, which I believe to be halfway down the line acoustically, is this right or do I have to make an adjustment to use in this position?
Old 1st June 2006, 02:26 PM   #2
GM is offline GM  United States
GM's Avatar
Default Re: Driver Position
Greets!
With no dimensions, how can anyone answer your Q? I mean you can't expect folks to go searching for BB's drawing and if the drawing is to scale it can't be exactly opposite since both sides of the pipe aren't the same length.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st June 2006, 07:26 PM   #3
Thanks, its easy to spot half way position in a straight tqwt, less so with folded particularly with rectangular port.
bib driver position skite30 Full Range 8 1st September 2008 07:35 AM
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 09:02 AM
Bass impact with driver position drfrink24 Subwoofers 18 26th January 2005 11:02 PM
Copyright 1999-2017 diyAudio
