to build curved front panel Jordan JX92?
Old 29th May 2006, 09:25 PM   #1
goodspeaker is offline goodspeaker  Ukraine
Send a message via AIM to goodspeaker Send a message via MSN to goodspeaker Send a message via Yahoo to goodspeaker
Default to build curved front panel Jordan JX92?
Hi
Does anyone made speaker with Jordan JX92 in curved front panel design?
I'm thinking to build the one.
with volume and port like MLTL-48 design.
Will it work good?
Old 30th May 2006, 03:41 PM   #2
Colin is offline Colin  United Kingdom
Do you mean like this ?
Old 30th May 2006, 04:24 PM   #3
Yes like this, but with one JX92.
Will it work good?
Does anybody build the one?
Old 30th May 2006, 07:26 PM   #4
pikkujöpö is offline pikkujöpö  Portugal
What difference does it make when the front panel is curved inwards?The front panels are normally curved outwards,are'n they?
I have planned to add some acrylic panels to widen MLTL:s.After some testing with cardboard the improvement is very noticeable.
xxx I should correct my spelling xxx
Old 30th May 2006, 09:28 PM   #5
With what MLTL design you do cardboard experiments? MLTL48 or MLTL31? What size of front panel you have?
I guess that with wide curved outwards front panel sound should be very good. So this is the reason to make me to want to build such speaker design.
Old 31st May 2006, 10:02 AM   #6
I don't think the curvey array design is available yet. I presume it is concave like that either as a styling exercise or because it loads the mid-bass in some way, perhaps to similulate the loading effect of an even wider baffle.
I can confirm that adding wings to the MLTL changes the tone of the driver output, giving it more body. As it happens in the upper bass, lower mid, it would work with both the 31 and 48 MLTL. Placing against a wall has a similar effect but in my experience the 48 MLTL goes bass-heavy if placed right back into corners.
Old 31st May 2006, 07:41 PM   #7
ravon is offline ravon  Netherlands
Default Re: to build curved front panel Jordan JX92?
Originally posted by goodspeaker
Hi
Will it work good?
I am planning to build a Konus Essence clone with a convex baffle.
Old 1st June 2006, 05:45 AM   #8
Nardis is offline Nardis  United Kingdom
Intriguing. Can you elaborate please? What exactly did you do? Are you referring to those very nice triangular cabinets you posted a picture of some time back?
What do wings do to the imaging? My own take on GM's 48 MLTL has very narrow baffles (155mm/6.15 inches) and images superbly. I would like to try to get a bit more body to the sound.
Old 1st June 2006, 07:14 AM   #9
DIAR is offline DIAR  Finland
DIAR's Avatar
My MLTL baffle is also very narrow. I tried adding baffles on both sides of cabinet and measured the effect.
Blue: narrow baffle (~16 cm)
Green: extra baffles > ~50 cm baffle
Turquoise: extra baffles tilted in about 15 degrees.
Old 1st June 2006, 10:54 AM   #10
Hi Nardis
i just placed a couple of sheets of foamboard either side of my triangular cabinets to see what the effect would be. It gave the tone more body but I only did it with one cabinet, so I don't know what it would do to the imaging. I found placing the cabinets next to the walls had a similar effect on the tone and no change to the imaging, at least in my room.
to build curved front panel Jordan JX92?Hide this!Advertise here!
Jordan JX92 w/ BG NEO 3? flatwallet Full Range 9 25th July 2008 03:26 PM
Looking for Jordan JX92 units chris ma Swap Meet 0 22nd September 2004 11:35 AM
Jordan Jx92 ANTHONY2181 Swap Meet 1 8th June 2004 07:51 PM
Jordan JX92 bookshelf TL Rafal Full Range 16 23rd January 2004 08:47 AM
