Cat 5 internal wiring, single strand or multiple? - Page 5 - diyAudio
Old 17th May 2006, 02:10 AM   #41
Originally posted by AndrewT
Hi Taperwood,
before you go committing yourself, try having a close look at CAT5 core insulation and compare it to foamed insulation from an appropriate coax.
Then tell us an informed opinion.
Andrew, what exactly would I be looking for? Unless someone comes on and informs us they are a chemical engineer in the field of foam insulation and sets us straight, I don't think anyone can make an informed opinion. We are all just joking around and speculating.
If foamed, do you think the insulation on coax would be identical to Cat5? They're two entirely different products.
Originally posted by Bob Brines
OK, I guess I need a bit of education here. PVC has twice the absorption coefficient as Teflon and therefore is twice as bad. But what is the time constant here? What is the rise time of the energy in the dielectric. Convert that to frequency and power level of the signal created by the dielectric?
Bob
Bob, the only reference to time I see is Vp (the speed of light). So teflon operates at 70%+ and PVC at 50%. Other than that, you got me.
Doug
Old 17th May 2006, 02:37 AM   #42
Google rules! search: FEP +insulation +foamed
At least for Belden, their Cat5 plenum uses an insulation called FEP. It's made by DuPont and is foamed.
There you go kind sirs, my informed opinion
Doug
Old 17th May 2006, 08:03 AM   #43
Hi Lostcause,
8pairs upto 3m long and 12pairs for 3m to 6m long
you chose to ignore this recomendation. Do you have the desire to try again?
Taperwood,
thanks for finding the reference.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th May 2006, 08:31 AM   #44
Lostcause's Avatar
Hi Lostcause, you chose to ignore this recomendation. Do you have the desire to try again?
Taperwood,
Already have done thanks Andrew and now I've managed to get it to about 4 metres.....by that recomendation (missed that one, sorry), I need to get another length in there as the 8 pair still has a lack of low base.
It's the sub 100hz that's lacking at the moment and it's choking the rest of the low/mid range.
If I play it at volume it actually sounds quite good but the neighbours (and the wife) would not agree
Cheers
Lee
Old 17th May 2006, 08:56 AM   #45
Hi Lostcause,
your name appears to be at odds with your mentallity!
With these lengths I think you should really consider bi-wiring. Achieves delicacy (2/3/4pair) for the treble and oomph ( 12pair) for the bass. The extra work, cost and volume is quite acceptable in return for the performance benefit.
If you cannot get this to work for you, we would all appreciate confirmation, good or bad.
regards Andrew T.
Old 17th May 2006, 09:14 AM   #46
Lostcause's Avatar
Hi Lostcause,
Sorry Andrew, it's Full-Rangers only....All for one and one for all......
Old 17th May 2006, 09:43 AM   #47
frugal-phile(tm)
planet10's Avatar
Old 17th May 2006, 02:47 PM   #48
understood, just ignore me!
regards Andrew T.
Old 26th June 2014, 11:07 AM   #49
Originally Posted by deiksac View Post
I would braid even more, perhaps 24 strands for + and another 24 strands for ground, using braided 3×CAT5 as ls connect sucks, not enough bass, braided cable made from 2×12×0,75 mm2 sounded ways better
http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=7602573999
Hmmm I.M.O using the equal logic, 12' speaker cables are 2 pair star wound Cat5. This can be possibly over-kill, although I have at least performed SOME THING a lot more than simply a sole run involving Cat5. The particular high count Cat5e Wiring Services formulation produce not any good sense other than to jack this wire capacitance outside of picture.
Old 30th June 2014, 09:30 AM   #50
Cat5 sucks a lot for audio (is an high-pass cable, due to its geometry).
Sat is mutch better (for both inside & outside speaker connection) in any sense, IMHO.
Internal wiring ceebmoj Chip Amps 8 23rd January 2008 10:01 PM
Internal Wiring... Tomv Multi-Way 1 23rd November 2007 08:53 AM
Internal amp wiring Bama Slamma Solid State 1 2nd November 2006 06:45 AM
Internal wiring Scribble Chip Amps 1 4th November 2004 05:52 AM
Internal wiring 2Bak Parts 5 29th July 2002 09:37 PM
Copyright ©1999-2017 diyAudio
