Cat 5 internal wiring, single strand or multiple?
Old 13th May 2006, 10:34 PM   #21
Lostcause is offline Lostcause  United Kingdom
Lostcause's Avatar
Surely if there is a different amount of twist then there is more cable in some of the twists yeh?
OK, OK, it probably wont make any difference......would it???
Old 13th May 2006, 11:01 PM   #22
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Let's see. At the speed of light, the signal will traverse a meter of cable in ~3e-9 seconds. And if the wires differ by a cm in length....'
Ok, the speed of the signal in copper will be slower than in a vacuum, but not that much.
smile
Bob
Old 14th May 2006, 02:17 AM   #23
Taperwood is offline Taperwood  United States
Oh man, so now you're saying that If I don't get the lengths exactly the same I'll now have to put the shorter wire in a vacuum?
Shoot! I knew I should have listened to my mother and taken up stamp collecting.
Old 14th May 2006, 06:24 PM   #24
Lostcause's Avatar
Hey, you joke.... but what about us novices that are told to keep the speaker wires the same length! Why?
Here we have a mix of wires some 30% longer than the other and of quite a high resistance....and then there's capacity....Oh my God, my brain hurts!!!!
Then I look at my BSC circuit and it has a resistor in it with one solitary wire thats less than 0.5mm diameter.....
What?
More Gin and Tonic.....that will make it better!
Old 14th May 2006, 07:17 PM   #25
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Bob's 1st question was what speaker... you also need to include amp in this equation. We are mostly playing with FE108ES/FE126/FE127 & CSS FR & WR driven by RH84, trioded class A EL84 PP (variant of El Cheapo with better iron), and MiniA.
We started out using Cat 5 with the 4 strips together & 4 solids together (and as many as 24 strands for speaker cable), and have slowly moved to single pairs of wires. These should be spearated. The last speaker cable shootout we did a single pair of cyro-treated PVC insulated Cat 5 wires was quite a bit better than a 4/4 section of Teflon insulated....
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th May 2006, 07:56 PM   #26
Lostcause's Avatar
dave
Is there an end to this?................ Do we suddenly attain enlightenment?.....help!
Old 14th May 2006, 08:50 PM   #27
frugal-phile(tm)
planet10's Avatar
No.
Old 14th May 2006, 08:57 PM   #28
westend is offline westend  United States
From a practical standpoint, the price of PVC Cat5 is low enough that you could make up many configurations of speaker cable and not break the bank. Using an SI T-amp on CSS FR125, FE126e, and others,I've found splitting the pairs (4 wire to + and 4 wires to -) and using the original sheath to be a workable solution.
Old 14th May 2006, 10:01 PM   #29
audioaficionado is offline audioaficionado  United States
audioaficionado's Avatar
Originally posted by Bob Brines
You are correct about out-of-the-box Cat5 cable. But, that is not what I was referring to. THIS is the 27 wire braided formula I had in mind: http://www.venhaus1.com/diycatfivecables.html. Tell me that this stuff doesn't have high capacitance!
You are also correct that all of these tweaks etc only apply way above the audio frequency range and that was sort of my point anyway.
Bob
Wow! Someone had a lot of time on their hands
~Steve
Old 14th May 2006, 10:36 PM   #30
frugal-phile(tm)
planet10's Avatar
Certainly the most expedient in terms of time.
BTW i have a 1000 ft roll of plenum grade Cat 5 -- the intention of which was to get cryotreated & do a "group buy" on.
dave
Cat 5 internal wiring, single strand or multiple?Hide this!Advertise here!
Internal wiring ceebmoj Chip Amps 8 23rd January 2008 10:01 PM
Internal Wiring... Tomv Multi-Way 1 23rd November 2007 08:53 AM
Internal amp wiring Bama Slamma Solid State 1 2nd November 2006 06:45 AM
Internal wiring Scribble Chip Amps 1 4th November 2004 05:52 AM
Internal wiring 2Bak Parts 5 29th July 2002 09:37 PM
