Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
gday!
TQWP almost done. some decoration will make latter. quality - so-so. hi range not enough and I have to make plane middle range .... but I'm happy ![]()
Artmaster live in www.artmaydan.org.ua |
#2 |
couldn't place 2 pictures at ones. that's because next appear
#3 |
What did you use to size them?
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/ |
#4 | |
do you mean finish, or box calculation?
#5 |
Box calc. And finish as well actually -it looks rather good in the pictures.
#6 | |
I'd calculate it, using Russian version of John Ratter's xls file. next time I'll tuning it higher - to 70hz and will use it with subwoofer. furthermore I will install tweeter. thank you for your opinion about finish. it's my first hand not marble coating.
#7 |
R.I.P.
check out the articles here : http://www.quarter-wave.com/General/..._Articles.html By implementing a filter, cutting back the midrange, you can improve treble. ![]() |
#8 |
Yes, that finish is very impressive. Wish I could do them like that.
I think this might be why you're finding the response a bit iffy. MathCad predicted response for that enclosure, using the SP-200X. I damped it down a bit with stuffing in the first half of the line. Nothing you can do about the big hole though. Pretty good for a Weems-based pipe though. Obviously the Monacor mates well to the Weems calculations.
#9 | |
another trobles - hump from 7k to 10kHz. I'm just hear this and it's annoy me.
#10 |
Yes, the SP200 is a bit hot across this region. Short of mechanical modifications, you'll need a filer to bring it into line a bit. You can reduce the hole to only 15db by stuffing the first half of the line with 1lb ft^3 of Dacron or similar.
Thread | Thread Starter | Forum | Replies | Last Post |
A fistful of Monacor SP-200X | Mikael Abdellah | Full Range | 20 | 17th August 2015 06:36 PM |
Monacor "Stage Line" STA-700 schema | edl | Solid State | 5 | 30th September 2012 09:17 AM |
What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
ML TQWT Monacor SP-200X | weidok | Full Range | 6 | 10th April 2006 05:40 AM |
Monacor "Kodex" 3 way dŽAppolito | wingman | Multi-Way | 3 | 17th July 2004 05:22 PM |
New To Site? | Need Help? |
